Jak w temacie może wymiana jakiegos tranzystorka do odbioru czy jakieś inne niezbyt skomplikowane modyfikacje ?
Znalazłem coś takiego :
http://members.tripod.com/~Malzev/cb-radio/grant_.htm
Czy ktoś może robił coś takiego bo mam nieoparta chęc zrobienia tego tylko nie wiem czy krecenie tymi l7 l8 czegoś nie rozstroji.
Cytat:Improved receive gain
Quieting of AM and SSB reception and improving gain of incoming signals is a common request from radio operators.
In the first stages of the HF input 2SC1674 transistor can be found. This transistor is responsible for the amplification of a small detected signals. A problems exist if the transistor itself is noisy as is such the case of the 2SC1674 when compared to other low noise packages. Along with the amplification of the incoming signals is transistor noise. Replacement of this transistor with a higher gain, lower noise transistor greatly improves the signal to noise ratio of your receiver.
We will use an 2SC2999 transistor that has higher gain lower noise characteristic. Replace the 2SC1674 (TR17) with an 2SC2999 (or similar low noise and high gain transistor) to achieve this improved signal to noise ratio.
Re-adjust L7 and L8
The gain will improved with more than 6dB with the same signal to noise ratio.
