Firmware pack TV Universal Control Board DS.V53RL.BK
remzibi 16 Sty 2019 17:42 495 0
  • #1 17705998
    remzibi
    Ocena: 889
    Marka:DS.V53RL.BK
    Model: DS.V53RL.BK
    Chassis (płyta lub główne podzespoły): TSUMV53
    Matryca/Panel (jeśli występuje): Większość matryc LVDS
    Inne (uwagi):
    1.DS.V53RL.BKis an analog TV control board, which is suitable for Asia-pacific and middle-east market.
    2.DS.V53RL.BK’s USB slot can be used for updating software and playing multimedia, such as MP3 and
    JPEG.
    3.DS.V53RL.BK’sHDMI support for the scheme is 1.3/1.4,HDCP1.2 compliant.
    Features
    CHIP:TSUMV53RUUL
    OSD LANGUAGE:English, Chinese
    Panel Type:TFT LCD With LED Backlight
    Panel Interface:1ch/2ch 6bit/8bit LVDS Interface
    Max Resolution:1920x1080
    TV Receiving Range:48.25MHz ~ 863.25MHz
    Video System:PAL,SECAM, NTSC
    Sound System:BG,DK,I,L,M,N NICAM/A2
    Max Storage Channels:199CH
    PC-RGB Format:Up to 1920×1080@60Hz
    CVBS Video System:PAL/NTSC/SECAM
    CVBS Video Level:1.0Vp-p±10%
    HDMI:480i, 480p, , 576i, 576p, 720I, 720p, 1080i, 1080p
    AUDIO INPUT:
    PC Audio Earphone Input Level 0.2~2.0VRMS
    CVBS Audio/Component Audio:L/R RCA Input 0.2~2.0VRMS
    VIDEO OUTPUT:
    Video level:1.0Vp-p±10%
    SPEAKER Frequency Response:100Hz~15K Hz @±3dB(1KHz 0dB Reference Signal)
    speaker Max Output Power:2×3W(4Ω) THD+N<10%@1KHz
    POWER DCInputvoltage :12VDC±0.6V
    power to To Panel :3.3V、5V、12V (there can be selected by Jumper Cap. The factory defaults to 5V)
    power Management:Standby Power Consumption < 0.3W(Board Only)
    power ADJ:0V ≤ ADJ ≤ 5.0V
    power BL ON:Standby mode :<0.5V On mode:>2.5V
    KEY FUNCTION:TV/AV,MENU,VOL+,VOL-, CH+,CH-,POWER
    Note:
    1.When 3.3V panel Irush≥1000mA,Inormal≥600mA,please contact wit DX engineers to confirm 3.3V panel power
    supply component selection.
    2.Max current of USB:500mA. The board is not suitable for all operating current less than 500mA
    Aby zobaczyć materiał na tym forum musisz być zalogowany Aby zobaczyć materiał na tym forum musisz być zalogowany
