FRST - laptop strasznie wolno działa. Prośba o analizę oraz fixlist.
adrianmielcarek0701 11 Gru 2022 23:12 216 6
  • #1 20330451
    adrianmielcarek0701
    Hej!
    Tak jak w temacie, prosiłbym jakąś dobrą duszę o analizę i fixlist :)
    Z góry dziękuje!
    • FRST.txt (36.5 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • Addition.txt (45.68 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #2 20330478
    Kolobos
    Spec od komputerów
    Ocena: 10448
    Jaki masz dysk? Zamiesc screen calego okna z CrystalDiskInfo Portable.
    Fixlist.txt:
    CloseProcesses:
    HKU\S-1-5-21-3076972848-2404791246-747506637-1001\...\Run: [CCleaner Smart Cleaning] => C:\Program Files\CCleaner\CCleaner64.exe [38789456 2022-10-20] (PIRIFORM SOFTWARE LIMITED -> Piriform Software Ltd)
    HKU\S-1-5-21-3076972848-2404791246-747506637-1001\...\Run: [MicrosoftEdgeAutoLaunch_CB50CB34C9AE5C62F78E6EAEBC5B5168] => "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --no-startup-window --win-session-start /prefetch:5 [3877280 2022-12-08] (Microsoft Corporation -> Microsoft Corporation)
    Task: {37292EA8-F458-47ED-A55C-5A3A1CCF5FD5} - \Microsoft\Windows\WindowsUpdate\sih -> Brak pliku <==== UWAGA
    Task: {3891CB81-CF07-4ECD-A7CE-59544F84AF7D} - \Microsoft\Windows\Shell\FamilySafetyMonitorToastTask -> Brak pliku <==== UWAGA
    Task: {55443FB5-ED89-4FD3-8C40-C9540C213A80} - \ACCBackgroundApplication -> Brak pliku <==== UWAGA
    Task: {56B3AFF3-4E35-46E1-BD00-341ABBF4F374} - \OneDrive Standalone Update Task v2 -> Brak pliku <==== UWAGA
    Task: {5970BBD1-04F5-4701-A413-123C796FD38D} - \Software Update Application -> Brak pliku <==== UWAGA
    Task: {85A2640B-58D1-4129-AFCA-17082F9B1496} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe [684976 2022-10-20] (Piriform Software Ltd -> Piriform)
    Task: {A28BED82-68DA-4965-81C6-EEBA0AE7B331} - System32\Tasks\CCleanerSkipUAC - adria => C:\Program Files\CCleaner\CCleaner.exe [32472400 2022-10-20] (PIRIFORM SOFTWARE LIMITED -> Piriform Software Ltd)
    Task: {BBF7FCA7-5E43-4A13-9773-1DCBDA0B4BAB} - \ACCAgent -> Brak pliku <==== UWAGA
    Task: {CDBC300A-8FD5-4345-8220-A79B78DDFEF5} - \Intel PTT EK Recertification -> Brak pliku <==== UWAGA
    Task: {CE4E8DAD-C809-4969-974C-ADEF1D96B67D} - \Acer Collection Monitor Application -> Brak pliku <==== UWAGA
    Task: {D0218C70-9C99-4043-BF17-667E1AE5C42E} - \Microsoft\Windows\UpdateOrchestrator\Reboot -> Brak pliku <==== UWAGA
    Task: {DF5C24EC-F6AD-491D-A238-D8A56879EF1B} - \ACC -> Brak pliku <==== UWAGA
    Task: {F7FF8035-88C9-43B2-9650-E96E04DBCACA} - System32\Tasks\CCleanerCrashReporting => C:\Program Files\CCleaner\CCleanerBugReport.exe [4669264 2022-10-20] (PIRIFORM SOFTWARE LIMITED -> Piriform Software) -> --product 90 --send dumps|report --path "C:\Program Files\CCleaner\LOG" --programpath "C:\Program Files\CCleaner" --configpath "C:\Program Files\CCleaner\Setup" --guid "766b1c44-466b-4dc7-88cf-e4359268b7ef" --version "6.05.10110" --silent
    Task: {FF4E7633-2D58-49C9-AB4D-7311A433BB08} - \UbtFrameworkService -> Brak pliku <==== UWAGA
    Task: {FF9656DF-076D-4F7F-988E-3D46CAF5F8F1} - \Acer Collection Application -> Brak pliku <==== UWAGA
    CHR HKLM\...\Chrome\Extension: [iikflkcanblccfahdhdonehdalibjnif]
    CHR HKLM-x32\...\Chrome\Extension: [iikflkcanblccfahdhdonehdalibjnif]
    2022-12-11 22:16 - 2022-12-11 22:16 - 000000000 ____D C:\Users\adria\Downloads\FRST-OlderVersion
  • #3 20330488
    adrianmielcarek0701
    Fixlist.txt:
    CloseProcesses:
    Pewnie dysk do wymiany?
    • FRST - laptop strasznie wolno działa. Prośba o analizę oraz fixlist. CrystalDiskInfo_20221211234713.png (99.69 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    pidar
    Ocena: 3585
    HDD do wymiany. :|
    O ile ten sprzęt na to jeszcze "pozwala" :wink: , to rozszerz też RAM.
    Kolobos
    Spec od komputerów
    Ocena: 10448
    Tak, wymien na SSD (np. MX500).
  • #6 20330514
    pidar
    Ocena: 3585
    I przy przesiadce na SSD-a, pomyśl o dołożeniu RAM-u lub wymień te aktualnie zamontowane kości pamięci.
    https://www.crucial.com/compatible-upgrade-for/acer/nitro-an515-31
    dt1
    Admin grupy komputery
    Ocena: 8263
    W zależności od wersji, płyta ma wlutowane 4 GB RAM i kolejne 4 GB w jednym i jedynym dostępnym na tej płycie slocie.
    Jeśli chodzi o użytek biurowy, www czy multimedia to te 8 GB może starczy. W przeciwnym wypadku można wymienić kość 4 GB na 8 GB (łącznie będzie 12 GB) lub na 16 GB (łącznie będzie 20 GB). Tyle max obsłuży laptop w wersji z wlutowanym 4GB RAM.
    Może mieć też dwa sloty. Można sprawdzić, jakie pamięci są zamontowane programem CPU-z (zrzut ekranu z zakładek memory oraz SPD, w SPD należy wybrać każdy slot, w którym pokażą się jakieś dane pamięci).
    https://download.cpuid.com/cpu-z/cpu-z_2.03-en.zip
    Co do dysku zaproponowany MX500 jest dobrym dyskiem, ale w tym laptopie (jeśli to AN515-31) da się z dużym prawdopodobieństwem zamontować dużo szybszy dysk M.2 PCIe - co prawda trzeba zdjąć dolną część obudowy, ale moim zdaniem warto to zrobić.
    https://www.youtube.com/watch?v=80T8sq_tU0M
✨ Laptop użytkownika działa wolno, co sugeruje problemy z dyskiem twardym. Użytkownicy zalecają wymianę HDD na SSD, na przykład model MX500, oraz rozważenie zwiększenia pamięci RAM. W przypadku modelu AN515-31, możliwe jest zainstalowanie szybszego dysku M.2 PCIe. Użytkownicy sugerują również użycie programu CPU-Z do sprawdzenia zainstalowanej pamięci RAM oraz jej możliwości rozbudowy.
