Po wgraniu sterowników acx100_pci wersja 49 i uruchomieniu start_network wysypuje na samym końcu taki błąd:
SIOCADDRT: Network is unreachable
w logach pojawia się coś takiego:
[root@localhost scripts]# tail -100 /var/log/messages
Nov 18 22:27:37 localhost kernel: continuing scan (attempt 3).
Nov 18 22:27:38 localhost kernel: acx_timer: status = 1
Nov 18 22:27:38 localhost kernel: continuing scan (attempt 4).
Nov 18 22:27:39 localhost kernel: acx_timer: status = 1
Nov 18 22:27:39 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:27:39 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:27:42 localhost kernel: acx_timer: status = 1
Nov 18 22:27:42 localhost kernel: continuing scan (attempt 1).
Nov 18 22:27:43 localhost kernel: acx_timer: status = 1
Nov 18 22:27:43 localhost kernel: continuing scan (attempt 2).
Nov 18 22:27:44 localhost kernel: acx_timer: status = 1
Nov 18 22:27:44 localhost kernel: continuing scan (attempt 3).
Nov 18 22:27:45 localhost kernel: acx_timer: status = 1
Nov 18 22:27:45 localhost kernel: continuing scan (attempt 4).
Nov 18 22:27:46 localhost kernel: acx_timer: status = 1
Nov 18 22:27:46 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:27:46 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:27:48 localhost kernel: acx_timer: status = 1
Nov 18 22:27:48 localhost kernel: continuing scan (attempt 1).
Nov 18 22:27:49 localhost kernel: acx_timer: status = 1
Nov 18 22:27:49 localhost kernel: continuing scan (attempt 2).
Nov 18 22:27:50 localhost kernel: acx_timer: status = 1
Nov 18 22:27:50 localhost kernel: continuing scan (attempt 3).
Nov 18 22:27:51 localhost kernel: acx_timer: status = 1
Nov 18 22:27:51 localhost kernel: continuing scan (attempt 4).
Nov 18 22:27:52 localhost kernel: acx_timer: status = 1
Nov 18 22:27:52 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:27:52 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:27:55 localhost kernel: acx_timer: status = 1
Nov 18 22:27:55 localhost kernel: continuing scan (attempt 1).
Nov 18 22:27:56 localhost kernel: acx_timer: status = 1
Nov 18 22:27:56 localhost kernel: continuing scan (attempt 2).
Nov 18 22:27:57 localhost kernel: acx_timer: status = 1
Nov 18 22:27:57 localhost kernel: continuing scan (attempt 3).
Nov 18 22:27:58 localhost kernel: acx_timer: status = 1
Nov 18 22:27:58 localhost kernel: continuing scan (attempt 4).
Nov 18 22:27:59 localhost kernel: acx_timer: status = 1
Nov 18 22:27:59 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:27:59 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:28:01 localhost kernel: acx_timer: status = 1
Nov 18 22:28:01 localhost kernel: continuing scan (attempt 1).
Nov 18 22:28:02 localhost kernel: acx_timer: status = 1
Nov 18 22:28:02 localhost kernel: continuing scan (attempt 2).
Nov 18 22:28:03 localhost kernel: acx_timer: status = 1
Nov 18 22:28:03 localhost kernel: continuing scan (attempt 3).
Nov 18 22:28:04 localhost kernel: acx_timer: status = 1
Nov 18 22:28:04 localhost kernel: continuing scan (attempt 4).
Nov 18 22:28:05 localhost kernel: acx_timer: status = 1
Nov 18 22:28:05 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:28:05 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:28:08 localhost kernel: acx_timer: status = 1
Nov 18 22:28:08 localhost kernel: continuing scan (attempt 1).
Nov 18 22:28:09 localhost kernel: acx_timer: status = 1
Nov 18 22:28:09 localhost kernel: continuing scan (attempt 2).
Nov 18 22:28:10 localhost kernel: acx_timer: status = 1
Nov 18 22:28:10 localhost kernel: continuing scan (attempt 3).
Nov 18 22:28:11 localhost kernel: acx_timer: status = 1
Nov 18 22:28:11 localhost kernel: continuing scan (attempt 4).
Nov 18 22:28:12 localhost kernel: acx_timer: status = 1
Nov 18 22:28:12 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:28:12 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:28:14 localhost kernel: acx_timer: status = 1
Nov 18 22:28:14 localhost kernel: continuing scan (attempt 1).
Nov 18 22:28:15 localhost kernel: acx_timer: status = 1
Nov 18 22:28:15 localhost kernel: continuing scan (attempt 2).
Nov 18 22:28:16 localhost kernel: acx_timer: status = 1
Nov 18 22:28:16 localhost kernel: continuing scan (attempt 3).
Nov 18 22:28:17 localhost kernel: acx_timer: status = 1
Nov 18 22:28:17 localhost kernel: continuing scan (attempt 4).
Nov 18 22:28:18 localhost kernel: acx_timer: status = 1
Nov 18 22:28:18 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:28:18 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:28:21 localhost kernel: acx_timer: status = 1
Nov 18 22:28:21 localhost kernel: continuing scan (attempt 1).
Nov 18 22:28:22 localhost kernel: acx_timer: status = 1
Nov 18 22:28:22 localhost kernel: continuing scan (attempt 2).
Nov 18 22:28:23 localhost kernel: acx_timer: status = 1
Nov 18 22:28:23 localhost kernel: continuing scan (attempt 3).
Nov 18 22:28:24 localhost kernel: acx_timer: status = 1
Nov 18 22:28:24 localhost kernel: continuing scan (attempt 4).
Nov 18 22:28:25 localhost kernel: acx_timer: status = 1
Nov 18 22:28:25 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:28:25 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:28:27 localhost kernel: acx_timer: status = 1
Nov 18 22:28:27 localhost kernel: continuing scan (attempt 1).
Nov 18 22:28:28 localhost kernel: acx_timer: status = 1
Nov 18 22:28:28 localhost kernel: continuing scan (attempt 2).
Nov 18 22:28:29 localhost kernel: acx_timer: status = 1
Nov 18 22:28:29 localhost kernel: continuing scan (attempt 3).
Nov 18 22:28:30 localhost kernel: acx_timer: status = 1
Nov 18 22:28:30 localhost kernel: continuing scan (attempt 4).
Nov 18 22:28:31 localhost kernel: acx_timer: status = 1
Nov 18 22:28:31 localhost kernel: Stopping scan<4>acx_complete_dot11_scan: no matching station found in range yet
Nov 18 22:28:31 localhost kernel: acx_set_status: Setting status = 1 (SCANNING)
Nov 18 22:28:34 localhost kernel: acx_timer: status = 1
Nov 18 22:28:34 localhost kernel: continuing scan (attempt 1).
Nov 18 22:28:35 localhost kernel: acx_timer: status = 1
Nov 18 22:28:35 localhost kernel: continuing scan (attempt 2).
Nov 18 22:28:36 localhost kernel: acx_timer: status = 1
Nov 18 22:28:36 localhost kernel: continuing scan (attempt 3).
