TOMZ-TOB9-63M z T1-U-HL , a nie BK7231N CBU
Link: https://www.aliexpress.com/item/1005005566505137.html
StartupCommand jest ustawione na startDriver BL0942
"bt1_pin":"17",
"led1_pin":"21",
"rl1_drvtime":"60",
"net_trig":"2",
"rl_on1_pin":"8",
"jv":"1.0.5",
"netled1_lv":"0",
"netled_reuse":"0",
"bt1_type":"0",
"temp_fun_en":"0",
"online_time":"10",
"nety_led":"1",
"rl_off1_pin":"6",
"over_cur":"63000",
"wide_vol":"1",
"bt1_lv":"0",
"reset_t":"5",
"netled1_pin":"15",
"equi_sampling":"mode_1",
"chip_type":"3",
"rl_on1_lv":"1",
"lose_vol":"80",
"over_vol":"265",
"module":"T1-U",
"ch_cddpid1":"9",
"ch1_stat":"2",
"led1_lv":"0",
"rl1_type":"1",
"ch_num":"1",
"ele_fun_en":"1",
"rl_off1_lv":"1",
"netn_led":"0",
"vol_def":"0",
"ch_dpid1":"1",
"crc":"37"
Device configuration, as extracted from Tuya:
- Button (channel 1) on P17
- LED (channel 1) on P21
- Bridge Relay On (channel 1) on P8
- Bridge Relay Off (channel 1) on P6
- WiFi LED on P15
Device seems to be using T1-U module, which is using BK7238.
And the Tuya section starts at 2052096, which is a default T1/XR806 and some T34 offset.
