"f=f(
" bo tam jest usmieszek w listingu
function demoai_fft(varargin)
%DEMOAI_FFT FFT display of an incoming analog input signal.
% DEMOAI_FFT creates an analog input object associated with the
% winsound adaptor with device identification 0. The incoming
% signal and the fft of the incoming signal of the created analog
% input object are plotted.
% DEMOAI_FFT('ADAPTORNAME', ID, CHANID) creates an analog input object
% associated with adaptor, ADAPTORNAME, with device identification,
% ID. A channel is assigned to the hardware channels specified in
% scalar CHANID. The incoming signal from the created analog input
% object and the fft of the incoming signal are both plotted.
% The plot is continuously updated by programming the TimerFcn
% property to plot the results from either GETDATA or PEEKDATA every
% 0.1 seconds (GETDATA is called for the initial plot).
% Examples:
% demoai_fft
% demoai_fft('winsound', 0, 1);
% MP 11-23-98
% Copyright 1998-2002 The MathWorks, Inc.
% $Revision: 1.6 $ $Date: 2002/04/04 22:11:58 $
% Error if an output argument is supplied.
if nargout > 0
error('Too many output arguments.');
end
% Based on the number of input arguments call the appropriate
% local function.
switch nargin
case 0
% Create the analog input object.
data = localInitAI;
% Create the figure.
data = localInitFig(data);
hFig = data.handle.figure;
case 1
error('The ADAPTORNAME, ID and CHANID must be specified.');
case 2
% Initialize variables.
data = [];
action=varargin{1};
hFig=varargin{2};
% This may fail if only the ADAPTORNAME and ID were input. However,
% if the ID was 0, this will work.
try
data=get(hFig,'UserData');
end
% DATA will be empty if CHANID was not specified or if ID = 0.
if isempty(data)
error('The CHANID must be specified.');
end
% Based on the action, call the appropriate local function.
switch action
case 'close'
localClose(data);
case 'stop'
data = localStop(data);
end
case 3
% User specified the input - adaptor, id, chanNum.
[data, errflag] = localInitAI(varargin{:});
if errflag
error(lasterr)
end
end
% Update the figure's UserData.
if ~isempty(hFig)&ishandle(hFig),
set(hFig,'UserData',data);
end
% Update the analog input object's UserData.
if isvalid(data.ai)
set(data.ai, 'UserData', data);
end
% Create the object and get the first fft.
function [data, errflag] = localInitAI(varargin)
errflag = 0;
data = [];
% Either no input arguments or all three - ADAPTORNAME, ID and CHANNELID.
switch nargin
case 0
adaptor = 'winsound';
id = 0;
chan = 1;
case 3
adaptor = varargin{1};
id = varargin{2};
chan = varargin{3};
otherwise
lasterr('The ADAPTORNAME, ID and CHANID must be specified.');
errflag = 1;
return;
end
% Error if more than one channel was specified.
if length(chan) > 1
lasterr('Only a single channel can be created.');
errflag = 1;
return
end
% Channel 2 for sound card is not allowed.
if strcmp(lower(adaptor), 'winsound') & chan == 2
warning('Channel 1 must be used for device Winsound.');
chan = 1;
end
% Object Configuration.
% Create an analog input object with one channel.
ai = analoginput(adaptor, id);
addchannel(ai, chan);
% Configure the analog input object.
set(ai, 'SampleRate', 44100);
% Configure the analog input object to trigger manually twice.
set(ai, 'SamplesPerTrigger', 1024);
set(ai, 'TriggerRepeat', 1);
set(ai, 'TriggerType', 'manual');
% Initialize callback parameters. The TimerAction is initialized
% after figure has been created.
set(ai, 'TimerPeriod', 0.1);
set(ai, 'BufferingConfig',[2048,20]);
% Object Execution.
% Start the analog input object.
start(ai);
trigger(ai);
% Obtain the available time and data.
[d,time] = getdata(ai, ai.SamplesPerTrigger);
% Calculate the fft.
Fs = get(ai, 'SampleRate');
blockSize = get(ai, 'SamplesPerTrigger');
[f,mag] = localDaqfft(d,Fs,blockSize);
% Update the data structure.
data.ai = ai;
data.getdata = [d time];
data.daqfft = [f mag];
data.handle = [];
% Set the object's UserData to data.
% Create the display.
function data = localInitFig(data)
btnColor=get(0,'DefaultUIControlBackgroundColor');
% Position the GUI in the middle of the screen
screenUnits=get(0,'Units');
set(0,'Units','pixels');
screenSize=get(0,'ScreenSize');
set(0,'Units',screenUnits);
figWidth=600;
figHeight=360;
figPos=[(screenSize(3)-figWidth)/2 (screenSize(4)-figHeight)/2 ...
figWidth figHeight];
% Create the figure window.
hFig=figure(...
'Color' ,btnColor ,...
'IntegerHandle' ,'off' ,...
'DoubleBuffer' ,'on' ,...
'DeleteFcn' ,'demoai_fft(''close'',gcbf)',...
'MenuBar' ,'none' ,...
'HandleVisibility' ,'on' ,...
'Name' ,'Analog Input FFT demo' ,...
'Tag' ,'Analog Input FFT demo' ,...
'NumberTitle' ,'off' ,...
'Units' ,'pixels' ,...
'Position' ,figPos ,...
'UserData' ,[] ,...
'Colormap' ,[] ,...
'Pointer' ,'arrow' ,...
'Visible' ,'off' ...
% Create Data subplot.
hAxes(1) = axes(...
'Position' , [0.1300 0.5811 0.7750 0.3439],...
'Parent' , hFig,...
'XLim' , [0 get(data.ai, 'SamplesPerTrigger')],...
'YLim' , [-0.5 0.5]...
% Plot the data.
hLine(1) = plot(data.getdata(:,1));
set(hAxes(1), 'XLim', [0 get(data.ai, 'SamplesPerTrigger')]);
% Label the plot.
xlabel('Sample');
ylabel('Analog Input (Volts)');
title('Analog Data Acquisition');
% Create the FFT subplot.
hAxes(2) = axes(...
'Position' , [0.1300 0.1100 0.7750 0.3439],...
'Parent' , hFig,...
'XLim' , [0 max(data.daqfft(:,1))]...
% Plot the data.
hLine(2) = plot(data.daqfft(:,1),data.daqfft(:,2));
set(hAxes(2), 'XLim', [0 max(data.daqfft(:,1))]);
% Label the plot.
xlabel('Frequency (Hz)');
ylabel('Magnitude (dB)');
% Create a start/stop pushbutton.
htoggle = uicontrol(...
'Parent' , hFig,...
'Style' , 'pushbutton',...
'Units' , 'normalized',...
'Position' , [0.0150 0.0111 0.1 0.0556],...
'Value' , 1,...
'String' , 'Stop',...
'Callback' , 'demoai_fft(''stop'', gcbf);');
hmenu(1) = uimenu('Parent', hFig,...
'Label', 'File');
hmenu(2) = uimenu(hmenu(1),...
'Label', 'Close demoai_fft',...
'Callback', 'demoai_fft(''close'',gcbf)');
hmenu(3) = uimenu('Parent', hFig,...
'Label', 'Help');
hmenu(4) = uimenu(hmenu(3),...
'Label', 'Data Acquisition Toolbox',...
'Callback', 'helpwin(''daq'')');
hmenu(5) = uimenu(hmenu(3),...
'Label', 'demoai_fft',...
'Callback', 'helpwin(''demoai_fft'')');
% Store the handles in the data matrix.
data.handle.figure = hFig;
data.handle.axes = hAxes;
data.handle.line = hLine;
data.handle.toggle = htoggle;
data.state = 0;
% Set the axes handlevisibility to off.
set(hAxes, 'HandleVisibility', 'off');
% Store the data matrix and display figure.
set(hFig,'Visible','on','UserData',data,'HandleVisibility', 'off');
% Configure the callback to update the display.
set(data.ai, 'TimerFcn', @localfftShowData);
% Close the figure window.
function localClose(data)
% Stop the device if it is running and delete the object.
if isvalid(data.ai)
if strcmp(get(data.ai, 'Running'), 'On')
stop(data.ai);
end
delete(data.ai);
end
delete(data.handle.figure);
% Stop or start the device.
function data = localStop(data)
% Based on the state either stop or start.
if strcmp(data.ai.Running, 'On')
% Stop the device.
stop(data.ai);
set(data.handle.toggle, 'String', 'Start');
% Store the new state.
data.state = 1;
else
% Toggle the Start/Stop string.
set(data.handle.toggle, 'String', 'Stop');
data.state = 0;
% Start the device.
start(data.ai);
end
% Calculate the fft of the data.
function [f, mag] = localDaqfft(data,Fs,blockSize)
xFFT = fft(data);
xfft = abs(xFFT);
% Avoid taking the log of 0.
index = find(xfft == 0);
xfft(index) = 1e-17;
mag = 20*log10(xfft);
mag = mag(1:blockSize/2);
f = (0:length(mag)-1)*Fs/blockSize;
f = f(
% Update the plot.
function localfftShowData(obj,event)
% Get the handles.
data = obj.UserData;
hAxes = data.handle.axes;
hLine = data.handle.line;
% Execute a peekdata.
x = peekdata(obj, obj.SamplesPerTrigger);
% FFT calculation.
Fs = obj.SampleRate;
blockSize = obj.SamplesPerTrigger;
[f,mag] = localDaqfft(x,Fs,blockSize);
% Dynamically modify Analog axis as we go.
maxX=max(x);
minX=min(x);
yax1=get(hAxes(1),'YLim');
if minX<yax1(1),
yax1(1)=minX;
end
if maxX>yax1(2),
yax1(2)=maxX;
end
set(hAxes(1),'YLim',yax1)
% Dynamically modify Frequency axis as we go.
maxF=max(f);
minF=min(f);
xax=get(hAxes(2),'XLim');
if minF<xax(1),
xax(1)=minF;
end
if maxF>xax(2),
xax(2)=maxF;
end
set(hAxes(2),'XLim',xax)
% Dynamically modify Magnitude axis as we go.
maxM=max(mag);
minM=min(mag);
yax2=get(hAxes(2),'YLim');
if minM<yax2(1),
yax2(1)=minM;
end
if maxM>yax2(2),
yax2(2)=maxM;
end
set(hAxes(2),'YLim',yax2)
% Update the plots.
set(hLine(1), 'YData', x(:,1));
set(hLine(2), 'XData', f(:,1), 'YData', mag(:,1));
str=get(data.handle.toggle, 'String');
if strcmp(str,'Start')
end
drawnow;
teraz skopiuj do edytora zapisz w m-pliku i odpal
Wylaczylem usmieszki - chcilem dolaczyc plik ale jakos ie nie udalo.
