Assemble with MPASM
; See below for wiring details
LIST P=16C84
__CONFIG 3FF9H ;XTAL OSC @4Mhz,NO WATCHDOG,PWRRST,NO CP.
__IDLOCS 1234
ERRORLEVEL -302
CNT1 EQU 0CH ;PRESCALLER COUNTER REG 1
CNT2 EQU 0DH ;PRESCALLER COUNTER REG 2
CNT3 EQU 0EH ;PRESCALLER COUNTER REG 3
TONREG EQU 0FH ;REGISTER FOR TONE NUMBER
PRES1 EQU 10H ;PRESCALLER STORE 1
PRES2 EQU 11H ;PRESCALLER STORE 2
PRES3 EQU 12H ;PRESCALLER STORE 3
PORTA EQU 5
PORTB EQU 6
TRISA EQU 85H
TRISB EQU 86H
OPTREG EQU 81H
PC EQU 2
PULLUP EQU 7
STATUS EQU 3
INTCON EQU 0BH
GIE EQU 7
RBIE EQU 3
RBIF EQU 0
RP0 EQU 5
OUT EQU 2
PTT EQU 7
GOTO START
ORG 00C8
START BSF STATUS,RP0 ;SELECT REG BANK 1
BSF TRISB,PTT ;SETUP RB7 AS INPUT FOR PTT
BCF TRISA,OUT ;SETUP RA2 AS OUTPUT FOR TONE
BCF OPTREG,PULLUP ;SET PULLUP RESISTORS ON PORTB
MOVLW 0xFF ; SET PORTB AS I/Ps
MOVWF TRISB ; RB0-RB5 FOR SWITCH INPUTS
BCF STATUS,RP0 ;SELECT REG BANK 0
BCF INTCON,GIE ;DISABLE GIE INTERUPTS
BSF INTCON,RBIE ;ENABLE PORT B CHANGE INTERUPT
MOVF TRISB,W ;READ DIP SWITCHES INTO W
MOVWF TONREG ;STORE IN 0F REG
BCF TONREG,6 ; CLEAR BITS 6&7 AS
BCF TONREG,7 ; THEY ARE IRRELAVANTS
MOVF TONREG,W ;RE-STORE INTO W
ADDWF TONREG,F ; MULTIPLY BY 3
ADDWF TONREG,F ; FOR TONE TABLE OFFSET
MOVF TONREG,W ;RELOAD TO W FOR OFFSET
CALL TONTBL ;GOTO TONE LOOKUP TABLE
MOVWF PRES1 ;STORE FIRST VALUE FROM TABLE
INCF TONREG,F ;INCREMENT FOR NEXT TABLE VALUE
MOVF TONREG,W ;RELOAD W FOR OFFSET
MOVWF PRES2 ;STORE SECOND VALUE FROM TABLE
MOVWF PRES3 ;STORE THIRD VALUE FROM TABLE
RELOAD
MOVF PRES1,W ;LOAD W WITH PRESET FOR 1
MOVWF CNT1 ;PRELOAD PRESCALLER 1
MOVF PRES2,W ;LOAD W WITH PRESET FOR 3
MOVWF CNT3 ;PRELOAD PRESCALLER 3
MOVF PRES3,W ;LOAD W WITH PRESET FOR 2 READY
PTTCHK
BTFSC PORTB,PTT ;TEST PTT LINE
GOTO WAIT ;SLEEP TILL LOW
CALL CHORUS ;DO DIVIDER/PRESCALLER ROUTINE
OUTPUT
BTFSS PORTA,OUT ;TEST O/P HI OR LO AT PRESENT
GOTO HI ;IF LO GO SET HI
GOTO LO ;IF HI GO SET LO
HI
NOP ;BALANCE OUT CYCLE TIME MARK&SPACE
BSF PORTA,OUT ;MAKE O/P HI
GOTO RELOAD ;RETURN TO START OF CYCLE
LO
BCF PORTA,OUT ;MAKE O/P LO
CHORUS
PRE1
DECFSZ CNT1,F ;DECREMENT PRESCALLER 1
GOTO PRE2
GOTO FINE ;CALL FINE ADJUST SUBROUTINE
PRE2 MOVWF CNT2 ;RELOAD PRESCALLER 2
PREE DECFSZ CNT2,F ;DECREMENT PRESCALLER 2
GOTO PREE ;GO BACK AND DECREMENT PRE2 TILL 00
GOTO PRE1 ;GO BACK AND DECREMENT PRE1 TILL 00
FINE DECFSZ CNT3,F ;DECREMENT PRESCALLER 3
GOTO FINE ;GO BACK AND DECREMENT PRE3 TILL 00
RETURN ;RETURN TO CHANGE O/P AND CHECK PTT ETC
WAIT
BCF INTCON,RBIF ;CLEAR PORT B CHANGE INT FLAG
SLEEP ;SLEEP AND WAIT FOR PTT
NOP
BCF INTCON,GIE ;DISABLE GLOBAL INTERUPTS AGAIN
GOTO PTTCHK ;CHECK IF PTT PASSES TEST
;TONES TABLE AT 0008H
ORG 0007H
TONTBL
ADDWF PC,F ; W+PC ->PC, JUMP DOWN TABLE
; 16c84 PIN
; 11 10 9 8 7 6
; TONE FREQ RB5 RB4 RB3 RB2 RB1 RB0
DT 02,01,0x9D ; 000 1Khz TEST 0 0 0 0 0 0
DT 86,82,10 ; 001 67.0 0 0 0 0 0 1
DT 81,85,10 ; 002 69.4 * 0 0 0 0 1 0
DT 84,80,0x0F ; 003 71.9 0 0 0 0 1 1
DT 7F,85,0x0F ; 004 74.4 0 0 0 1 0 0
DT 7B,7C,0x0F ; 005 77.0 0 0 0 1 0 1
DT 76,86,0x0F ; 006 79.7 0 0 0 1 1 0
DT 72,82,0x0F ; 007 82.5 0 0 0 1 1 1
DT 74,8F,0x0E ; 008 85.4 0 0 1 0 0 0
DT 63,91,10 ; 009 88.5 0 0 1 0 0 1
DT 5F,9A,10 ; 010 91.5 0 0 1 0 1 0
DT 5B,47,11 ; 011 94.8 0 0 1 0 1 1
DT 55,88,11 ; 012 97.4 0 0 1 1 0 0
DT 56,49,11 ; 013 100.0 0 0 1 1 0 1
DT 09,6E,0xB9 ; 014 103.5 0 0 1 1 1 0
DT 08,81,0xC9 ; 015 107.2 0 0 1 1 1 1
DT 0A,71,98 ; 016 110.9 0 1 0 0 0 0
DT 0B,76,83 ; 017 114.8 0 1 0 0 0 1
DT 0A,0xCA,83 ; 018 118.8 0 1 0 0 1 0
DT 0A,9A,83 ; 019 123.0 0 1 0 0 1 1
DT 09,0xF1,83 ; 020 127.3 0 1 0 1 0 0
DT 08,93,9D ; 021 131.8 0 1 0 1 0 1
DT 07,94,0xB0 ; 022 136.5 0 1 0 1 1 0
DT 07,7C,0xAD ; 023 141.3 0 1 0 1 1 1
DT 07,85,0xA5 ; 024 146.2 0 1 1 0 0 0
DT 08,7B,89 ; 025 151.4 0 1 1 0 0 1
DT 08,80,83 ; 026 156.7 0 1 1 0 1 0
DT 07,0xA2,90 ; 027 159.8 * 0 1 1 0 1 1
DT 08,47,86 ; 028 162.2 0 1 1 1 0 0
DT 07,60,95 ; 029 165.5 * 0 1 1 1 0 1
DT 08,86,78 ; 030 167.9 0 1 1 1 1 0
DT 07,92,87 ; 031 171.3 * 0 1 1 1 1 1
DT 07,90,85 ; 032 173.8 1 0 0 0 0 0
DT 07,7D,85 ; 033 177.3 * 1 0 0 0 0 1
DT 09,5A,66 ; 034 179.9 1 0 0 0 1 0
DT 09,48,66 ; 035 183.5 * 1 0 0 0 1 1
DT 07,9E,78 ; 036 186.2 1 0 0 1 0 0
DT 08,0xBB,60 ; 037 189.9 * 1 0 0 1 0 1
DT 09,4C,60 ; 038 192.8 1 0 0 1 1 0
DT 08,9D,60 ; 039 196.6 * 1 0 0 1 1 1
DT 09,2F,60 ; 040 199.5 * 1 0 1 0 0 0
DT 07,82,70 ; 041 203.5 1 0 1 0 0 1
DT 07,76,70 ; 042 206.5 * 1 0 1 0 1 0
DT 07,66,70 ; 043 210.7 1 0 1 0 1 1
DT 07,6F,6A ; 044 218.1 1 0 1 1 0 0
DT 06,0xA3,70 ; 045 225.7 1 0 1 1 0 1
DT 06,98,70 ; 046 229.1 * 1 0 1 1 1 0
DT 06,8A,70 ; 047 233.6 1 0 1 1 1 1
DT 06,72,70 ; 048 241.8 1 1 0 0 0 0
DT 04,0xC3,99 ; 049 250.3 1 1 0 0 0 1
DT 04,0xB9,99 ; 050 254.1 * 1 1 0 0 1 0
DT 05,1C,99 ; 051 255 * 1 1 0 0 1 1
DT 03,15,20 ; 052 1750 Eu Tone 1 1 0 1 0 0
DT 05,0F,10 ; 053 1800 Eu Tone 1 1 0 1 0 1
DT 01,84,9D ; 054 1200 Packet 1 1 0 1 1 0
DT 02,13,30 ; 055 2200 Packet 1 1 0 1 1 1
DT 03,26,50 ; 056 800 * 1 1 1 0 0 0
DT 03,0F,50 ; 057 900 * 1 1 1 0 0 1
DT 02,3F,50 ; 058 1100 * 1 1 1 0 1 0
DT 03,36,20 ; 059 1300 * 1 1 1 0 1 1
DT 01,68,20 ; 060 1500 * 1 1 1 1 0 0
DT 03,09,20 ; 061 2000 * 1 1 1 1 0 1
DT 02,1A,20 ; 062 2500 * 1 1 1 1 1 0
DT 02,07,20 ; 063 3500 * 1 1 1 1 1 1
; * Indicates non EIA standard tone
ORG 2100H
DE "TonyHunt VK5AH CTCSSENC v 1.4 "
END
All CTCSS tones are within EIA standard of .08% .
Use a 4Mhz crystal with 2x18pF capacitors.
PTT line is active LOW. PTT is RB7 Pin 13.
OUTPUT tone is on RA2 Pin1 ,see Low pass filter diag.
Lines RB0-RB5 can be fitted with DIP switches to set
tone frequencies as per table above. A 1 on the table
indicates the RB pin is logic HI . All RB port pins have
been programmed with internal pullup resistors and will
float HI if left open. The binary inputs are read only on
power up and not each time the PTT is keyed.
For CTCSS tones use a Low pass filter as shown here as the
output waveform is square. RO is an padding resistor to
allow for level adjustment typically 20k.
RA2--------2k2----------RO----Output
Pin1 |
1uF
GND
