Błąd przy uruchamianiu LMS 1.8.1 Shyla - wyświetla kod PHP
krakow2000 11 Lut 2008 20:45 3591 5
  • #1 4795090
    krakow2000
    Chce wejść do LMS-a i wyskakuje mi takie coś:
    <?php
    * LMS version 1.8.1 Shyla
    * (C) Copyright 2001-2006 LMS Developers
    * Please, see the doc/AUTHORS for more information about authors!
    * This program is free software; you can redistribute it and/or modify
    * it under the terms of the GNU General Public License Version 2 as
    * published by the Free Software Foundation.
    * This program is distributed in the hope that it will be useful,
    * but WITHOUT ANY WARRANTY; without even the implied warranty of
    * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    * GNU General Public License for more details.
    * You should have received a copy of the GNU General Public License
    * along with this program; if not, write to the Free Software
    * Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307,
    * USA.
    * $Id: index.php,v 1.180.2.3 2006/01/27 07:26:35 alec Exp $
    // REPLACE THIS WITH PATH TO YOUR CONFIG FILE
    $CONFIG_FILE = (is_readable('lms.ini')) ? 'lms.ini' : '/etc/lms/lms.ini';
    // PLEASE DO NOT MODIFY ANYTHING BELOW THIS LINE UNLESS YOU KNOW
    // *EXACTLY* WHAT ARE YOU DOING!!!
    // Parse configuration file
    function lms_parse_ini_file($filename, $process_sections = false)
    $ini_array = array();
    $section = '';
    $lines = file($filename);
    foreach($lines as $line)
    $line = trim($line);
    if($line == '' || $line[0] == ';' || $line[0] == '#')
    continue;
    list($sec_name) = sscanf($line, "[%[^]]");
    if( $sec_name )
    $section = trim($sec_name);
    else
    list($property, $value) = sscanf($line, "%[^=] = '%[^']'");
    if ( !$property || !$value )
    list($property, $value) = sscanf($line, "%[^=] = \"%[^\"]\"");
    list($property, $value) = sscanf($line, "%[^=] = %[^;#]");
    if( !$property || !$value )
    continue;
    else
    $value = trim($value, "\"'");
    $property = trim($property);
    $value = trim($value);
    if($process_sections)
    $ini_array[$section][$property] = $value;
    else
    $ini_array[$property] = $value;
    return $ini_array;
    foreach(lms_parse_ini_file($CONFIG_FILE, true) as $key => $val)
    $CONFIG[$key] = $val;
    // Check for configuration vars and set default values
    $CONFIG['directories']['sys_dir'] = (!isset($CONFIG['directories']['sys_dir']) ? getcwd() : $CONFIG['directories']['sys_dir']);
    $CONFIG['directories']['backup_dir'] = (!isset($CONFIG['directories']['backup_dir']) ? $CONFIG['directories']['sys_dir'].'/backups' : $CONFIG['directories']['backup_dir']);
    $CONFIG['directories']['doc_dir'] = (!isset($CONFIG['directories']['doc_dir']) ? $CONFIG['directories']['sys_dir'].'/documents' : $CONFIG['directories']['doc_dir']);
    $CONFIG['directories']['lib_dir'] = (!isset($CONFIG['directories']['lib_dir']) ? $CONFIG['directories']['sys_dir'].'/lib' : $CONFIG['directories']['lib_dir']);
    $CONFIG['directories']['modules_dir'] = (!isset($CONFIG['directories']['modules_dir']) ? $CONFIG['directories']['sys_dir'].'/modules' : $CONFIG['directories']['modules_dir']);
    $CONFIG['directories']['config_templates_dir'] = (!isset($CONFIG['directories']['config_templates_dir']) ? $CONFIG['directories']['sys_dir'].'/config_templates' : $CONFIG['directories']['config_templates_dir']);
    $CONFIG['directories']['smarty_dir'] = (!isset($CONFIG['directories']['smarty_dir']) ? (is_readable('/usr/share/php/smarty/libs/Smarty.class.php') ? '/usr/share/php/smarty/libs' : $CONFIG['directories']['lib_dir'].'/Smarty') : $CONFIG['directories']['smarty_dir']);
    $CONFIG['directories']['smarty_compile_dir'] = (!isset($CONFIG['directories']['smarty_compile_dir']) ? $CONFIG['directories']['sys_dir'].'/templates_c' : $CONFIG['directories']['smarty_compile_dir']);
    $CONFIG['directories']['smarty_templates_dir'] = (!isset($CONFIG['directories']['smarty_templates_dir']) ? $CONFIG['directories']['sys_dir'].'/templates' : $CONFIG['directories']['smarty_templates_dir']);
    foreach(lms_parse_ini_file($CONFIG['directories']['lib_dir'].'/config_defaults.ini', TRUE) as $section => $values)
    foreach($values as $key => $val)
    if(! isset($CONFIG[$section][$key]))
    $CONFIG[$section][$key] = $val;
    $_SYSTEM_DIR = $CONFIG['directories']['sys_dir'];
    $_BACKUP_DIR = $CONFIG['directories']['backup_dir'];
    $_DOC_DIR = $CONFIG['directories']['doc_dir'];
    $_LIB_DIR = $CONFIG['directories']['lib_dir'];
    $_MODULES_DIR = $CONFIG['directories']['modules_dir'];
    $_SMARTY_DIR = $CONFIG['directories']['smarty_dir'];
    $_SMARTY_COMPILE_DIR = $CONFIG['directories']['smarty_compile_dir'];
    $_SMARTY_TEMPLATES_DIR = $CONFIG['directories']['smarty_templates_dir'];
    $_DBTYPE = $CONFIG['database']['type'];
    $_DBHOST = $CONFIG['database']['host'];
    $_DBUSER = $CONFIG['database']['user'];
    $_DBPASS = $CONFIG['database']['password'];
    $_DBNAME = $CONFIG['database']['database'];
    require_once($_LIB_DIR.'/checkdirs.php');
    require_once($_LIB_DIR.'/checkconfig.php');
    // Init database
    require_once($_LIB_DIR.'/LMSDB.php');
    $DB = DBInit($_DBTYPE, $_DBHOST, $_DBUSER, $_DBPASS, $_DBNAME);
    // Enable/disable data encoding conversion
    // Call any of upgrade process before anything else
    require_once($_LIB_DIR.'/dbencoding.php');
    require_once($_LIB_DIR.'/upgradedb.php');
    // Initialize templates engine (must be before locale settings)
    require_once($_SMARTY_DIR.'/Smarty.class.php');
    $SMARTY = new Smarty;
    // test for proper version of Smarty
    if(version_compare('2.6.0', $SMARTY->_version) > 0)
    die('Old version of Smarty engine! You must get newest from <A HREF="http://smarty.php.net/distributions/Smarty-2.6.8.tar.gz">http://smarty.php.net/distributions/Smarty-2.6.8.tar.gz</A>');
    // Read configuration of LMS-UI from database
    if($cfg = $DB->GetAll('SELECT section, var, value FROM uiconfig WHERE disabled=0'))
    foreach($cfg as $row)
    $CONFIG[$row['section']][$row['var']] = $row['value'];
    // Redirect to SSL
    $_FORCE_SSL = (isset($CONFIG['phpui']['force_ssl']) ? chkconfig($CONFIG['phpui']['force_ssl']) : FALSE);
    if($_FORCE_SSL && $_SERVER['HTTPS'] != 'on')
    header('Location: https://'.$_SERVER['HTTP_HOST'].$_SERVER['REQUEST_URI']);
    exit(0);
    // Include required files (including sequence is important)
    require_once($_LIB_DIR.'/language.php');
    require_once($_LIB_DIR.'/unstrip.php');
    require_once($_LIB_DIR.'/definitions.php');
    require_once($_LIB_DIR.'/common.php');
    require_once($_LIB_DIR.'/checkip.php');
    require_once($_LIB_DIR.'/LMS.class.php');
    require_once($_LIB_DIR.'/Auth.class.php');
    require_once($_LIB_DIR.'/accesstable.php');
    require_once($_LIB_DIR.'/Session.class.php');
    // Initialize Session, Auth and LMS classes
    $SESSION = new Session($DB, $CONFIG['phpui']['timeout']);
    $AUTH = new Auth($DB, $SESSION);
    $LMS = new LMS($DB, $AUTH, $CONFIG);
    $LMS->lang = $_language;
    // set some template and layout variables
    $SMARTY->assign_by_ref('_LANG', $_LANG);
    $SMARTY->assign_by_ref('LANGDEFS', $LANGDEFS);
    $SMARTY->assign_by_ref('_language', $LMS->lang);
    $SMARTY->assign('_dochref', is_dir('doc/html/'.$LMS->lang) ? 'doc/html/'.$LMS->lang.'/' : 'doc/html/en/');
    $SMARTY->assign('_config',$CONFIG);
    $SMARTY->template_dir = $_SMARTY_TEMPLATES_DIR;
    $SMARTY->compile_dir = $_SMARTY_COMPILE_DIR;
    $SMARTY->debugging = (isset($CONFIG['phpui']['smarty_debug']) ? chkconfig($CONFIG['phpui']['smarty_debug']) : FALSE);
    $SMARTY->_tpl_vars['missing_strings'] = array();
    require_once($_LIB_DIR.'/smarty_addons.php');
    require_once($_LIB_DIR.'/menu.php');
    $layout['logname'] = $AUTH->logname;
    $layout['logid'] = $AUTH->id;
    $layout['lmsdbv'] = $DB->_version;
    $layout['smarty_version'] = $SMARTY->_version;
    $layout['hostname'] = hostname();
    $layout['lmsv'] = '1.8.1 Shyla';
    $layout['lmsvr'] = $LMS->_revision.'/'.$AUTH->_revision;
    $layout['dberrors'] =& $DB->errors;
    $SMARTY->assign_by_ref('newmenu', $menu);
    $SMARTY->assign_by_ref('layout', $layout);
    header('X-Powered-By: LMS/'.$layout['lmsv']);
    $error = NULL; // initialize error variable needed for (almost) all modules
    $layout['popup'] = $_GET['popup'];
    if($AUTH->islogged)
    $module = (isset($_GET['m']) ? $_GET['m'] : '');
    $deny = FALSE;
    if (file_exists($_MODULES_DIR.'/'.$module.'.php'))
    if(eregi($access['allow'], $module))
    $allow = TRUE;
    else{
    $rights = $LMS->GetUserRights($AUTH->id);
    if($rights)
    foreach($rights as $level)
    if(isset($access['table'][$level]['deny_reg']) && eregi($access['table'][$level]['deny_reg'], $module))
    $deny = TRUE;
    elseif(isset($access['table'][$level]['allow_reg']) && eregi($access['table'][$level]['allow_reg'], $module))
    $allow = TRUE;
    if($allow && ! $deny)
    $layout['module'] = $module;
    include($_MODULES_DIR.'/'.$module.'.php');
    else
    $SMARTY->display('noaccess.html');
    elseif($module == '')
    $layout['module'] = 'welcome';
    include($_MODULES_DIR.'/welcome.php');
    else
    $layout['module'] = 'notfound';
    $layout['pagetitle'] = trans('Error!');
    $SMARTY->assign('layout', $layout);
    $SMARTY->assign('server', $_SERVER);
    $SMARTY->display('notfound.html');
    if($SESSION->get('lastmodule') != $module)
    $SESSION->save('lastmodule', $module);
    else
    $SMARTY->assign('error', $AUTH->error);
    $SMARTY->assign('target','?'.$_SERVER['QUERY_STRING']);
    $SMARTY->display('login.html');
    $SESSION->close();
    $DB->Destroy();
    i ni jak mogę się zalogować... help me pleas !!!!!
  • #2 4795241
    JacoMan
    Ocena: 2
    Twoj serwer nie ma obslugi php.
  • #3 4795268
    krakow2000
    apacha mam ale coś w nim chyba "zepsułem". czy jak ściągnę nowego i zainstaluje to nie muszę tego starego odinstalować?? Jeśli muszę to jak tego dokonać??
  • #4 4795300
    JacoMan
    Ocena: 2
    Tak apacha masz, racja.
    Jak dzialalo wczesniej to i miales php i faktycznie zepsules.
    Nie musisz reinstalowac apacha, jedynie naprawic/zainstalowac php.
    Cos zmieniales w konfigach? Jezeli tak wycofaj zmiany, poszukaj w logach dlaczego nie rusza php, moze to jakad drobnostka.
    Jak nie miales php/nie dzialalo wczesniej poszukaj w googlach informacji jak doinstalowac php.
  • #5 4795406
    krakow2000
    Zassałem "nowego" apache ale nie instalowałem go jeszcze bo zapewne będę musiał bawić się w ustawienia a chcę tego uniknąć.
    Jak mogę "naprawić" ten problem ?? Dodam, że jestem ZIELONY w linuxsie i jakiś temat albo coś łopatologicznie bym prosił... będę wdzięczny... jak narazie tylko psuje :)
  • #6 4795584
    JacoMan
    Ocena: 2
    Przypomnij sobie czy zmieniales cos w configach apacha?
    Wklej error.log z apacha, z liniami gdzie jest cos o php.
