z przejściówką jest bardzo ciężko
nigdzie jej zdobyć nie można ;(
dziś dostałem również router cisco 1600 niestety po likwidacji hasła uległ uszkodzeniu softwarowemu ;(
po restacir wyskakuje komunikat:
Router(boot):
jak przywrócić router do normalnego działania ?
System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C1600 platform with 16384 Kbytes of main memory
program load complete, entry point: 0x4020060, size: 0x165eac
%SYS-6-READ_BOOTFILE_FAIL: flash:c1600-reboot-r File boot failed -- File not acc
essible.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
boot of "cisco2-C1600" using boot helper "eprom:c1600-rboot-r.120-3.T" failed
error returned: File boot failed -- File not accessible
loadprog: error - on file open
boot: cannot load "cisco2-C1600"ę
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"ę
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) 1600 Software (C1600-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 22-Feb-99 23:05 by ccai
Image text-base: 0x04020060, data-base: 0x02005000
cisco 1601 (68360) processor (revision C) with 15872K/512K bytes of memory.
Processor board ID 16983588, with hardware revision 00000002
1 Ethernet/IEEE 802.3 interface(s)
Interface 1 unrecognized by boothelper
System/IO memory with parity disabled
8192K bytes of DRAM onboard 8192K bytes of DRAM on SIMM
System running from ROM
8K bytes of non-volatile configuration memory.
6144K bytes of processor board PCMCIA flash (Read/Write)
Press RETURN to get started!
00:00:01: %C1600-4-INTFCNOFLH: Unable to load images or communicate over interf
ace
00:00:03: %LINK-5-CHANGED: Interface Ethernet0, changed state to administrativel
y down
00:00:04: %SYS-5-CONFIG_I: Configured from memory by console
00:00:04: %SYS-5-RESTART: System restarted --
cisco(boot)>
