Czy mi się zdaje czy ilość sektorów niestabilnych jest większa niż być powinna? Zgrywać dane i robić procedurę naprawczą czy trzeba inaczej podejść do problemu?
SMART oraz informacje o ostatnich pięciu błędach:
Spoiler:
smartctl 5.42 2011-10-20 r3458 [i686-linux-3.4.4-lesslinux-000] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Seagate Momentus 5400.3
Device Model: ST9120822AS
Serial Number: xxxxxxx
Firmware Version: 3.ALB
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 7
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Wed May 14 13:11:59 2014 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 426) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
No General Purpose Logging support.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 111) minutes.
SCT capabilities: (0x0001) SCT Status supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 100 253 006 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 099 099 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 092 092 020 Old_age Always - 8996
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 087 060 030 Pre-fail Always - 4787730114
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 9983
10 Spin_Retry_Count 0x0013 100 100 034 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 093 093 020 Old_age Always - 7806
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 339
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 068 041 045 Old_age Always In_the_past 32 (Min/Max 26/32)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1469
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 305177
194 Temperature_Celsius 0x0022 032 059 000 Old_age Always - 32 (0 11 0 0 0)
195 Hardware_ECC_Recovered 0x001a 093 061 000 Old_age Always - 120522396
197 Current_Pending_Sector 0x0012 001 001 000 Old_age Always - 4294967294
198 Offline_Uncorrectable 0x0010 001 001 000 Old_age Offline - 4294967294
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 16
200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0
202 Data_Address_Mark_Errs 0x0032 100 253 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 399 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 399 occurred at disk power-on lifetime: 9600 hours (400 days + 0 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 8f ba 2b e0 Error: UNC at LBA = 0x002bba8f = 2865807
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 40 67 ba 2b e0 00 00:48:04.440 READ DMA
c8 00 01 00 00 00 e0 00 00:48:04.422 READ DMA
c8 00 80 d7 e9 3f e2 00 00:48:04.414 READ DMA
c8 00 80 d7 4e 36 e2 00 00:48:04.397 READ DMA
c8 00 08 57 ba e6 e1 00 00:48:04.382 READ DMA
Error 398 occurred at disk power-on lifetime: 9600 hours (400 days + 0 hours)
c8 00 40 67 ba 2b e0 00 00:47:59.810 READ DMA
ca 00 20 f7 0e c6 e3 00 00:47:59.809 WRITE DMA
c8 00 80 57 e9 3f e2 00 00:47:59.809 READ DMA
c8 00 80 57 4e 36 e2 00 00:47:59.808 READ DMA
ca 00 50 57 a5 9b e1 00 00:47:59.808 WRITE DMA
Error 397 occurred at disk power-on lifetime: 9600 hours (400 days + 0 hours)
c8 00 40 67 ba 2b e0 00 00:47:55.414 READ DMA
ca 00 08 f7 4f 02 e0 00 00:47:55.375 WRITE DMA
e7 00 00 00 00 00 a0 00 00:47:55.367 FLUSH CACHE
c8 00 80 d7 e8 3f e2 00 00:47:55.347 READ DMA
c8 00 80 d7 4d 36 e2 00 00:47:55.347 READ DMA
Error 396 occurred at disk power-on lifetime: 9600 hours (400 days + 0 hours)
c8 00 40 67 ba 2b e0 00 00:47:50.905 READ DMA
c8 00 01 00 00 00 e0 00 00:47:50.904 READ DMA
c8 00 80 57 e8 3f e2 00 00:47:50.904 READ DMA
c8 00 80 57 4d 36 e2 00 00:47:50.903 READ DMA
ca 00 10 47 94 86 e1 00 00:47:50.902 WRITE DMA
Error 395 occurred at disk power-on lifetime: 9600 hours (400 days + 0 hours)
c8 00 40 67 ba 2b e0 00 00:47:46.502 READ DMA
e7 00 00 00 00 00 a0 00 00:47:46.501 FLUSH CACHE
c8 00 80 d7 e7 3f e2 00 00:47:46.500 READ DMA
c8 00 80 d7 4c 36 e2 00 00:47:46.500 READ DMA
ca 00 80 ff 5d 4d e1 00 00:47:46.499 WRITE DMA
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
ATA Version is: 7
been run.
command.
power-saving mode.
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
