CPUID HWMonitor Report
Mainboard Model B85 Pro4 (0x00000234 - 0x0099DDC6)
Hardware monitor Nuvoton NCT6776
Voltage 0 0.88 Volts [0x6E] (CPU VCORE)
Voltage 1 1.78 Volts [0xDF] (VIN1)
Voltage 2 3.36 Volts [0xD2] (AVCC)
Voltage 3 3.36 Volts [0xD2] (3VCC)
Voltage 4 0.94 Volts [0x76] (VIN4)
Voltage 5 1.71 Volts [0xD6] (VIN5)
Voltage 6 0.86 Volts [0x6C] (VIN6)
Temperature 0 36°C (96°F) [0x24] (SYSTIN)
Temperature 1 36°C (96°F) [0x48] (CPUTIN)
Temperature 2 33°C (91°F) [0x42] (AUXTIN)
Temperature 3 52°C (125°F) [0x34] (TMPIN3)
Fan 0 940 RPM [0x3AC] (SYSFANIN)
Fan 1 1439 RPM [0x59F] (CPUFANIN)
Hardware monitor AMD ADL
Voltage 0 1.26 Volts [0x4E8] (VIN0)
Temperature 0 60°C (140°F) [0x3C] (TMPIN0)
Fan 0 2276 RPM [0x8E4] (FANIN0)
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.417 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 4690
Codename Haswell
Specification Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84 Watts
Tjmax 100.0 °C
Core Speed 3497.9 MHz
Multiplier x Bus Speed 35.0 x 99.9 MHz
Stock frequency 3500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T,
Turbo Mode supported, enabled
Max non-turbo ratio 35x
Max turbo ratio 35x
Max efficiency ratio 8x
O/C bins none
Ratio 1 core 35x
Ratio 2 cores 35x
Ratio 3 cores 35x
Ratio 4 cores 35x
TSC 3499.1 MHz
APERF 3499.0 MHz
MPERF 3499.1 MHz
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
DriverMSG napisał: pacjent1972 napisał: Komputer kupiony trzy miesiące temu więc myślę że Bios ma najnowszą wersję
To o niczym nie świadczy.
pacjent1972 napisał: Gdzie to sprawdzić i jaki to ma wpływ na brak Turbo Boosta?
Wersja wyświetlana jest na starcie komputera.
Wpływ ma taki, ze dopiero od wersji w/w płyta obsługuje twój procesor.
Zaraz zresetuje kompa i sprawdzę.
Dodano po 6 [minuty]: Wersja Bios to P2.10
