[Rozwiązano] Skoda Fabia II - sonda lambda - kontrolka Check engine i błędy VCDS
Pioter.K 27 Lut 2018 21:43 6582 4
  • #1 17068660
    Pioter.K
    Ocena: 57
    Witam Wszystkich
    bardzo proszę o pomoc w interpretacji błędów z VCDS.
    Co ciekawe kontrolka Check engine zapaliła się przy 56495 km czyli dużo później niż wykazały błędy i tego nie rozumiem.
    Zapis błędów.
    "Tuesday,27,February,2018,07:13:51:49450
    VCDS Version: Release 16.8.0 Running on Windows 7 x64
    Address 01: Engine Labels: 03E-906-019-CGP.clb
    Control Module Part Number: 03E 906 019 C HW: 03E 906 019 C
    Component and/or Version: SIMOS11.1 H03 1433
    Software Coding: 00110016000400000000
    Work Shop Code: WSC 13765 031 00053
    ASAM Dataset: EV_ECM12MPI02103E906019C 001004 (SK25)
    ROD: EV_ECM12MPI02103E906019AC.rod
    VCID: 244786F62F1AD562E4-8070
    3 Faults Found:
    16906 - Oxygen (Lambda) Sensor B1 S1
    P0132 00 [237] - Signal too High
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 12
    Mileage: 55676 km
    Date: 2070.14.30
    Time: 12:11:57
    Engine speed: 1893.00 /min
    Normed load value: 43.9 %
    Vehicle speed: 67 km/h
    Coolant temperature: 78 °C
    Intake air temperature: 0 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 14.523 V
    Unlearning counter according OBD: 40
    Oxygen sensor bank 1 sensor 1: voltage-Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.046 V
    Heated oxygen sensor bank 1: sensor 1: resistance-Lambda probe heater: resistance: bank 1: probe 1: 65535 Ohm
    Voltage terminal 30: 14.319 V
    Time since engine start: 7 s
    16907 - Oxygen (Lambda) Sensor B1 S1
    P0133 00 [237] - Response too Slow
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 56254 km
    Date: 2072.14.22
    Time: 06:54:39
    Engine speed: 1622.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 57 km/h
    Coolant temperature: 69 °C
    Intake air temperature: -6 °C
    Ambient air pressure: 1010 mbar
    Oxygen sensor bank 1 sensor 1: voltage-Lambda probe voltage: bank 1: probe 1 (broadband probe): 0.469 V
    Engine status-Engine: operating status: PUC
    Cold start counter: dew point end of front lambda probe-CTR_COLD_ST_LS_UP: 0
    Exhaust gas temperature before catalytic converter-TEG_DYN_LS_UP[1]: 586.72501 °C
    16882 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
    P2097 00 [101] - Too Rich
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 55676 km
    Date: 2070.14.30
    Time: 12:11:55
    Engine speed: 1889.00 /min
    Normed load value: 50.6 %
    Oxygen sensor bank 1 sensor 2 (jump sensor): 0.115 V / -50.00 %(lean)"
  • #2 17068970
    Raywood
    Ocena: 16
    Świece zapłonowe się kończą.
  • #3 17069026
    migmig85
    Ocena: 337
    Czy silnik chodzi równo ??
  • #4 17070860
    Pioter.K
    Ocena: 57
    tak nie ma żadnych anomalii w postaci wypadania zapłonów. Silnik chodzi równo ale jakby bardziej mułowato. Przy naciśnięciu gazu do dechy zanim zacznie przyśpieszać na 5 biegu mija chwila, ale nie dławi się ani nie prycha tylko po prostu ma jakby opóźnienie części sekundy zanim zacznie przyśpieszać.
    no niestety nie. Brak wypadania zapłonów itp. Poza tym silnik pracuje równiutko.
  • #5 19182148
    Pioter.K
    Ocena: 57
    Wymiana sondy lambda (sterującej) rozwiązała problem.
