00:00.0 Host bridge: nVidia Corporation nForce2 IGP2 (rev c1)
Subsystem: ABIT Computer Corp. Device 1c02
Flags: bus master, 66MHz, fast devsel, latency 0
Memory at e8000000 (32-bit, prefetchable) [size=64M]
Capabilities: [40] AGP version 3.0
Capabilities: [60] HyperTransport: Host or Secondary Interface
Kernel driver in use: agpgart-nvidia
Kernel modules: nvidia-agp
00:00.1 RAM memory: nVidia Corporation nForce2 Memory Controller 1 (rev c1)
Subsystem: nVidia Corporation Device 0c17
Flags: 66MHz, fast devsel
00:00.2 RAM memory: nVidia Corporation nForce2 Memory Controller 4 (rev c1)
00:00.3 RAM memory: nVidia Corporation nForce2 Memory Controller 3 (rev c1)
00:00.4 RAM memory: nVidia Corporation nForce2 Memory Controller 2 (rev c1)
00:00.5 RAM memory: nVidia Corporation nForce2 Memory Controller 5 (rev c1)
00:01.0 ISA bridge: nVidia Corporation nForce2 ISA Bridge (rev a4)
Subsystem: ABIT Computer Corp. NF7-S/NF7 (nVidia-nForce2) 2.X
Capabilities: [48] HyperTransport: Slave or Primary Interface
00:01.1 SMBus: nVidia Corporation nForce2 SMBus (MCP) (rev a2)
Flags: 66MHz, fast devsel, IRQ 10
I/O ports at ec00 [size=32]
Capabilities: [44] Power Management version 2
Kernel driver in use: nForce2_smbus
Kernel modules: i2c-nforce2
00:02.0 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 21
Memory at ef002000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
Kernel modules: ohci-hcd
00:02.1 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 20
Memory at ef003000 (32-bit, non-prefetchable) [size=4K]
00:02.2 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4) (prog-if 20 [EHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 22
Memory at ef004000 (32-bit, non-prefetchable) [size=256]
Capabilities: [44] Debug port: BAR=1 offset=0080
Capabilities: [80] Power Management version 2
Kernel driver in use: ehci_hcd
Kernel modules: ehci-hcd
00:04.0 Ethernet controller: nVidia Corporation nForce2 Ethernet Controller (rev a1)
Memory at ef000000 (32-bit, non-prefetchable) [size=4K]
I/O ports at e000 [size=8]
Kernel driver in use: forcedeth
Kernel modules: forcedeth
00:08.0 PCI bridge: nVidia Corporation nForce2 External PCI Bridge (rev a3) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: ee000000-eeffffff
Kernel modules: shpchp
00:09.0 IDE interface: nVidia Corporation nForce2 IDE (rev a2) (prog-if 8a [Master SecP PriP])
Subsystem: Device f47b:1c02
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
I/O ports at f000 [size=16]
Kernel driver in use: pata_amd
Kernel modules: pata_amd, amd74xx
00:1e.0 PCI bridge: nVidia Corporation nForce2 AGP (rev c1) (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, medium devsel, latency 32
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
Memory behind bridge: ec000000-edffffff
Prefetchable memory behind bridge: e0000000-e7ffffff
01:07.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Subsystem: Innovative Integration Device 2001
Flags: bus master, medium devsel, latency 32, IRQ 5
Memory at ee000000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [40] Power Management version 1
Kernel modules: saa7134
01:08.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. RT8139
Flags: bus master, medium devsel, latency 32, IRQ 16
I/O ports at d000 [size=256]
Memory at ee001000 (32-bit, non-prefetchable) [size=256]
Capabilities: [50] Power Management version 2
Kernel driver in use: 8139too
Kernel modules: 8139cp, 8139too
01:0a.0 Multimedia audio controller: Ensoniq 5880 AudioPCI (rev 02)
Subsystem: Ensoniq Creative Sound Blaster AudioPCI128
Flags: bus master, slow devsel, latency 32, IRQ 18
I/O ports at d400 [size=64]
Capabilities: [dc] Power Management version 1
Kernel driver in use: ENS1371
Kernel modules: snd-ens1371
02:00.0 VGA compatible controller: nVidia Corporation NV34 [GeForce FX 5200] (rev a1) (prog-if 00 [VGA controller])
Subsystem: PROLINK Microsystems Corp Device 1152
Flags: bus master, 66MHz, medium devsel, latency 248, IRQ 19
Memory at ec000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (32-bit, prefetchable) [size=128M]
[virtual] Expansion ROM at ed000000 [disabled] [size=128K]
Capabilities: [60] Power Management version 2
Capabilities: [44] AGP version 3.0
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nvidia173
