Witam chętnie kupię uC Attiny22 lub też proszę fanatyków - elektroników o edycję programu do obsługi RC5 (*.asm w załączniku).
Więcej na temat układu, który chcę uruchomić jest na https://www.elektroda.pl/rtvforum/topic797491.html
ps. hex pomyślnie zaprogramowałem na Attiny13, niestety nie działa to. (nawet nie zapisuje kudu RC5 w EEPROM)
ASM - RC5
ASM - RC5
;**** T I T L E R C 5 T I N Y L A M P ***************************************
;* Title :RC5TinyLamp
;* Version :1.0
;* Date :00.05.31
;* Last updated :00.08.19
;* Target :ATTiny22
;* Crystal frequency :1Mhz intern oscillator
;* Support :J.v.Boxtel
;* Support E-mail :boxteldoelen@hetnet.nl
;* Code Size :149 words
;* Low Register Usage :5
;* High Register Usage :11
;* Interrupt Usage :
;* Based on :avr410 rc5, avr100 EEprom access, RC5Lamp
;* DESCRIPTION
;* This Application switch a lamp on/off with RC5 if
;* system and lamp_nr are correct
;* system and lamp_nr are can be change with the "learn_button"
;* pB2 (pin7) is IRinput, pB3 (pin2) is learn button, pB0 (pin5) is output
;* pB3 learbutton open=normal groud=learn
;* pB1 (pin6) ext interrupt
.include "tn22def.inc"
.equ INPUT =2 ;PB2 input for ir reciever
.def S =R0 ;Storage for the Status Register
.def inttemp =R1 ;Temporary variable for ISR
.def ref1 =R2 ;Reference for timing
.def ref2 =R3 ;Reference for timing
.def EEdrd =R4 ;read data byte from EEprom
.def temp =R16 ;Temporary variable
.def timerL =R17 ;Timing variable updated every 14 us
.def timerH =R18 ;Timing variable updated every 16 ms
.def system =R19 ;Address data received
.def command =R20 ;Command received
.def bitcnt =R21 ;Counter
.def SYS_ADDR =R22 ;Systen addres to respond on
.def LAMP_NR =R23 ;Lamp number to respond on
.def EEard =R24 ;address to read from
.def EEdwr =R25 ;data byte to write to EEPROM
.def EEawr =R26 ;address byte to write to
.cseg
.org 0
rjmp reset
;* "TIM0_OVF" - Timer/counter overflow interrupt handler
;* The overflow interrupt increments the "timerL" and "timerH"
;* every 64us and 16,384us.
;* Crystal Frequency is 1 MHz
;* Number of words:
;* Number of cycles:6 + reti
;* Low registers used:1
;* High registers used: 3
;* Pointers used:0
.org OVF0addr
TIM0_OVF:
in S,sreg ; Store SREG
inc timerL ; Updated every 64us
inc inttemp ; 4 MHz clock
inc inttemp ; 3 MHz clock
inc inttemp ; 2 MHz clock
inc inttemp ; 1 MHz clock
brne TIM0_OVF_exit
inc timerH ; if 256th int inc timer
TIM0_OVF_exit:
out sreg,S ; Restore SREG
reti
reset:
ldi temp,1 ;Timer/Counter 0 clocked at CK
out TCCR0,temp ; Timer counter 0 prescaler
ldi temp,1<<TOIE0 ;Enable Timer0 overflow interrupt
out TIMSK,temp ; set timer interrupt mask
ldi temp,0x01 ;PORTB 0 as output
out DDRb,temp ; set direction
ldi temp,15 ;load 15 for init pullup on pB1,pB2;pB3
out portb,temp ; and set defaul lamp off after reset
ldi temp,ramend ;init stack pointer
out spl,temp ; ram_end to spl
sei ;Enable global interrupt
main:
rcall detect ;Call RC5 detect routine
cpi command,0xFF ;If no or wrong code return to main
breq main
in temp,pinb ;learbutton test
andi temp,$08 ; test pb3 only (learnbutton)
cpi temp,$08 ; high then main1
breq main1
mov EEdwr,system ;store new system addres in EEprom
ldi EEawr,$00 ; at addres 00
rcall EEWrite ; store system in EEPROM location $0000
andi command,0x3F ;remove toggle bit
mov EEdwr,command ;store new command in EEprom
ldi EEawr,$01 ; at addres $0001
rcall EEWrite ; store command in EEPROM location $0001
main1:
rcall readin ;readin the system-addres and lamp_nr
cp system,sys_addr ;correct addres? else return to main
brne main
cp command,lamp_nr ;correct lamp nr? else return to main
brne main
invert:
brts invert1 ;if T bit is 0 then lamp on
set ;set t bit (lamp on code)
cbi $18,0 ;port pin low =lamp on
rjmp wait ;jump to wait
invert1: ;if t bit is 1 then lamp off
clt ;clear t bit (lamp off code)
sbi $18,0 ;set pin high
wait:
rcall detect ;Call RC5 detect routine and
cpi command,0xFF ; wait until button is released
brne wait ;
rjmp main ;
readin:
ldi EEard,$00 ;load addres
rcall EERead ;read address $00 (System addres)
mov sys_addr,EEdrd ;load system addres
ldi EEard,$01 ;load addres
rcall EERead ;read address $01 (command number)
mov lamp_nr,EEdrd ;command mumber is lamp number
ret
;* EERead
;* This subroutine waits until the EEPROM is ready to be programmed, then
;* reads the register variable "EEdrd" from address "EEardh:EEard"
;* Number of words :1200 ; 5 + return
;* :8515 ; 6 + return
;* Number of cycles :1200 ; 8 + return (if EEPROM is ready)
;* :8515 ; 9 + return (if EEPROM is ready)
;* Low Registers used :1 (EEdrd)
;* High Registers used: :2 (EEard,EEardh)
EERead:
sbic EECR,EEWE ;if EEWE not clear
rjmp EERead ; wait more
out EEAR,EEard ;output address for 1200
sbi EECR,EERE ;set EEPROM Read strobe
;This instruction takes 4 clock cycles since
;it halts the CPU for two clock cycles
in EEdrd,EEDR ;get data
ret
EEWrite:
rjmp EEWrite ; wait more
out EEARL,EEawr ;output address low
out EEDR,EEdwr ;output data
sbi EECR,EEMWE ; set master write enable
sbi EECR,EEWE ; set EEPROM Write strobe
; This instruction takes 4 clock cycles since
; it halts the CPU for two clock cycles
ret
;* "detect" - RC5 decode routine
;* This subroutine decodes the RC5 bit stream applied on PORTB
;* pin "INPUT".
;* If success: The command and system address are
;* returned in "command" and "system".
;* Bit 6 of "command" holds the toggle bit.
;* If failed: $FF in both "system" and "command"
;* Crystal frequency is 4MHz
;* Number of words:72
;* Low registers used: 3
;* High registers used: 6
;* Pointers used: 0
detect0: ;only for test
ldi command,0x7
ldi system,0x05
ret
detect:
clr inttemp ; Init Counters
clr timerH
detect1:
clr timerL
detect2:
cpi timerH,8 ;If line not idle within 131ms
brlo dl1
rjmp fault ;then exit
dl1:
cpi timerL,55 ;If line low for 3.5ms
brge start1 ;then wait for start bit
sbis PINB,INPUT ;If line is
rjmp detect1 ;low - jump to detect1
rjmp detect2 ;high - jump to detect2
start1:
cpi timerH,8 ;If no start bit detected
brge fault ;within 130ms then exit
sbic PINB,INPUT ;Wait for start bit
rjmp start1
clr timerL ;Measure length of start bit
start2:
cpi timerL,17 ;If startbit longer than 1.1ms,
brge fault ;exit
sbis PINB,INPUT
rjmp start2 ;Positive edge of 1st start bit
mov temp,timerL ;timer is 1/2 bit time.
clr timerL
mov ref1,temp
lsr ref1
mov ref2,ref1
add ref1,temp ;ref1 = 3/4 bit time
lsl temp
add ref2,temp ;ref2 = 5/4 bit time
start3:
cp timerL,ref1 ;If high period St2 > 3/4 bit time
brge fault ;exit
sbic PINB,INPUT ;Wait for falling edge start bit 2
rjmp start3
clr timerL
ldi bitcnt,12 ;Receive 12 bits
clr command
clr system
sample:
cp timerL,ref1 ;Sample INPUT at 1/4 bit time
brlo sample
sbic PINB,INPUT
rjmp bit_is_a_1 ;Jump if line high
bit_is_a_0:
clc ;Store a ’0’
rol command
rol system
;Synchronize timing
bit_is_a_0a:
cp timerL,ref2 ;If no edge within 3/4 bit time
brge fault ;exit
sbis PINB,INPUT ;Wait for rising edge
rjmp bit_is_a_0a ;in the middle of the bit
clr timerL
rjmp nextbit
bit_is_a_1:
sec ;Store a ’1’
rol command
rol system
;Synchronize timing
bit_is_a_1a:
brge fault ;exit
rjmp bit_is_a_1a ;in the middle of the bit.
clr timerL
nextbit:
dec bitcnt ;If bitcnt > 0
brne sample ;get next bit
;All bits sucessfully received!
mov temp,command ;Place system bits in "system"
rol temp
rol system
rol temp
rol system
andi command,0b01111111
andi system,0x1F
ret
fault:
ser command ;Both "command" and "system"
ser system ;0xFF indicates failure
ret
.eseg
.org 0
table:
.db $00,$04 ;KTV1, button 4 default settings
