Fuser Error. blad grzalki...
a to cytat z serwisowki:
"Fuser Error. This indicates a fusing
assembly malfunction.
Note: Chronic fuser failures or fuser
overheating or both are indicators of an
uninterruptible power supply or battery
backup being used with the printer.
Uninterruptible power supplies (UPS)
should notbe used with the printer.
1. Unplug the printer for 10 minutes or more.
2. Verify that the fuser connector is firmly seated in
J102 of the DC Controller PCA and that the
thermistor connector (left of fusing assembly) is
seated into both the printer chassis and J206 of the
DC Controller PCA.
3. Remove the connector from J102 of the DC
Controller (See Figure 6-14). Measure the resistance
between pins one and two of the cable. (This
procedure will measure the continuity of the ceramic
heating element.) Normal resistance is 30 ohms +/-
10 ohms. If no resistance is measured, replace the
heating element.
4. Remove the thermistor (temperature feedback)
connector (See Figure 7-3). Measure the resistance
between pins one and two. Normal resistance is
440K ohms +/- 30K at 20 degrees C. If the resistance
is not measured replace the heating element.
5. If the resistance readings are correct, yet the error
persists, replace the DC Controller."
