Jak zdjąć simlock z Sony Ericsson K800i CID52? Problemy z portem 9 i ID loaderem
kowal00071 02 Sty 2008 13:32 2827 2
  • #1 4649335
    kowal00071
    Ocena: 30
    Witam mam k800i do simlocka tel jest na cid 52, wcześniej robiłem taki z 51 i niemiałem problemów a teraz simlock nie zchodzi, co robie nie tak
    zaznaczam unlack after flash
    use server for.....
    enable alternative security bypass
    v0.914020/UNI
    CARD SERIAL: 00052989
    Loaded 51 flash descriptors
    llbug: port 9 open error: "Nieprawidłowe dojście"
    Can't load ID loader !
    Elapsed:0 secs.
    Elapsed:0 secs.
    Open COM port OK
    ChipID:9900,EMP protocol:0301
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    OTP LOCKED:1 CID:51 PAF:1 IMEI:35731501955702 CERT:N/A
    FLASH CID:52 COLOR:RED
    Model:K800i
    MAPP CXC article: R1JG001 prgCXC1250210_GENERIC_WI
    MAPP CXC version: R1JG001
    Language Package:CENT_EUROPE
    CDA article: CDA102568/2
    CDA version: R9A
    Default article: cxc1250490
    Default version: R1KG001
    Network LOCKED
    Operator: 234-15
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed:10 secs.
    SERVER SUPPORT ENABLED.
    ALTERNATIVE SECURITY BYPASS ENABLED.
    Open COM port OK
    Speed:921600
    PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
    LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
    Flash ID check:897E
    Flash props sent ok
    CID52 BYPASS PROCEDURE STARTED
    Processing part1...
    Processing part2...
    Processing part3....
    Open COM port OK
    Flash ID check:897E
    Flash props sent ok
    RESTARTING PHONE,IF PHONE NOT RESTARTS,THEN
    REMOVE BATTERY FROM PHONE AND INSERT IT BACK
    Open COM port OK
    CID52 BYPASS PROCEDURE FINISHED
    bypassing security...
    Open COM port OK
    Speed:921600
    Trying to launch embedded bootloader...
    Embedded flashloader:
    DB2020_PRELOADER_FOR_SETOOL2
    Flash ID check:897E
    Flash props sent ok
    writing C:\Documents and Settings\Mobile world\Pulpit\SOFT\SE\k800 setool\cid 52\inny\R1JG001_1250210_GENERIC_WI.ssw
    CURRENT FLASH FILE CID:52
    SSW uses complete hash, hash len is:9200
    Will flash 460 blocks...
    SSW loading returns:0
    full sig complete.
    USERCODE RESET TO "0000"
    Searching...
    Firmware lock check determined.
    Elapsed:1140 secs.
    po włączeniu tela na wyświetlaczu pisze :configuration error. Plase contact your network operator or service centre
  • #2 4649401
    dziekanone
    Poziom 29  
    Ocena: 15
    zrób customizacje ;) i będzie śmigał
  • #3 4649406
    poochone
    Ocena: 165
    jak go flashowales zapomniales w zakladce settings zaznaczyc complett i nie zrobilo ci customizacji zrob jeszcze raz to samo z ta opcja bedzie na pewno dobrze
