Suzuki Ignis podłączenie sterownika centralnego zamka
wecia91 04 Lis 2009 13:09 4909 1
    sadek1979
    Spec od samochodów
    Ocena: 1421
    MAKE SUZUKI MOD. IGNIS YEAR. 02 2nd sem.® PETROL
    DIESEL
    ALARM/SIREN
    POSITION
    Position the compact alarms and the sirens on the support of the shock
    absorber, driver’s side. Pass the cables through the original rubber sleeve
    located in the bulkhead that divides the engine compartment and the driver’s side
    passenger’s compartment , the same rubber sleeve of the bonnet opening wire.
    CENTRAL UNIT POSITION The modular systems and the modules should be positioned under the
    dashboard, driver’s side.
    POWER SUPPLY +30: connect to the 3 mm2 RED wire located in a multiway connector, in the fuse
    box.
    -31: connect to one of the ground terminal located behind the left lateral
    bulkhead, driver’s side.
    IGNITION WIRE +15/54: Connect to the YELLOW wire with SILVER references located in the
    wiring harness behind the sill cover, driver’s side.
    DIRECTION INDICATORS Connect to the BLUE/YELLOW wire with SILVER references and to the
    GREEN/RED wire with SILVER references located in the wiring harness behind
    the driver’s side sill cover.
    ELECTRIC WINDOWS Positive control signal
    Front window, driver’s side:
    cut the the RED wire with SILVER references located in the wiring harness
    coming out of the control switch, directly inside the driver’s side door.
    Front window, passenger’s side:
    cut the RED/WHITE wire with SILVER references, at the position nr. 7, coming
    out of the 14 way white connector, located under the dashboard driver’s side, in
    the upper part of the bulkhead.
    CENTRAL DOORS LOCKING Negative control signal
    Connect to the BROWN/WHITE wire with SILVER references (unlock) and to the
    BROWN wire with SILVER references (lock) in the 14 way white connector,
    located in the upper part, under the driver’s side dashboard.
    IMMOBILISATION POINT Fuel pump
    Cut the PINK wire with SILVER references located in the wiring harness behind
    STARTER +50: Cut the 1,5 mm2 BLACK/YELLOW wire located in the 6 way white
    connector, directly on the coming out of the ignition key.
    BONNET SWITCH Install an additional switch on the front headlamp support plate, driver’s side.
    DOORS AND BOOT SWITCH Connect to the BLACK/RED wire located in the wiring harness behind the
    • SUIGN02GBB2S.PDF (29.55 KB) Musisz być zalogowany, aby pobrać ten załącznik.
