VAG TACHO USB 3.01 - Błąd odczytu PIN w Sharan 1999r. - EEPROM krzaczki?
smykus1991 01 Cze 2012 17:16 3527 8
  • #1 10956343
    smykus1991
    witam mam problem otóż: korzystam z programu VAG TACHO USB 3.01 i podczas odczytania PIN do immobilizera wyskakuje ni taki komunikat:
    Go Ahead!
    Trying to Read Immobilizer PIN code...
    Please wait...
    Loading commands...
    OK
    OK
    OK
    Reset kombi...
    OK
    OK
    Execute commands...
    OK
    OK
    Disconnect...
    OK
    Reading data from interface...
    Try PIN CODE: 0000
    Try PIN CODE: 0000
    Unknown eeprom data!
    Press View Memory Buffer to see EEPROM data!
    Proszę o jakiekolwiek porady.
    Dodaję memory buffor: - czy to przez krzaczki po prawje jest kłopot? Jeśli tak to jak się ich pozbyć
    0000:20 20 21 20 20 57 41 52 4E 49 4E 47 20 20 21 20 ! WARNING !
    0010:20 20 47 41 52 42 41 47 45 20 44 41 54 41 20 20 GARBAGE DATA
    0020:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0030:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0040:00 00 00 00 00 00 00 00 00 00 00 10 00 01 00 00 ...............
    0050:00 00 00 00 00 50 50 34 00 00 00 E5 00 00 00 00 .....PP4...ĺ....
    0060:00 00 00 00 00 00 00 00 00 00 00 36 00 00 1D 08 ...........6...
    0070:CB 04 F6 08 CC F6 08 CF 1C 08 CB 08 CE 0C 00 18 Ë.ö.Ěö.Ď.Ë.Î .
    0080:0D 30 08 CF 1F 08 CC 40 FB C6 55 7B 08 17 C6 AA 0.Ď.Ě@űĆU{.ĆŞ
    0090:7B 08 17 8E 10 00 25 E7 CE 00 2A 86 05 36 05 05 {.Ž.%çÎ.*†.6..
    00A0:11 18 00 00 00 00 00 00 64 01 5A 2D 45 DA A5 5A ......d.Z-EÚĄZ
    00B0:01 04 37 21 99 81 00 00 00 00 00 00 76 A5 5A 81 ..7!™......vĄZ
    00C0:04 5A 2D 45 DA 2A 00 00 00 00 00 00 6C 01 00 00 .Z-EÚ*......l...
    00D0:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00E0:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00F0:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0100:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
  • #2 10957370
  • #3 10958099
    grala1
    Specjalista grupy V.A.G.
    Ocena: 5052
    Kolega wybrał odpowiedni rodzaj puszki immo?
  • #4 10958592
    smykus1991
    tylko w tym mam jakikolwiek odczyt w reszcie mam: Access Denied
    VW Sharan 1999r.
  • #5 10959601
    grala1
    Ocena: 5052
    Więc nie odczytasz tym PINu.
  • #6 10959804
    smykus1991
    a jak mam to zrobić?
  • #7 10961282
    grala1
    Ocena: 5052
    Jaki masz nr puszki immo?
    Przy połączeniu powinni podać nr.
    Lub napisz jak wygląda transponder w kluczu - czarny prostokącik czy szklana rurka.
  • #8 10961761
    smykus1991
    Czarny prostokącik - dokładnie :) - numeru transpondera nie sprawdzę bo nie wiem gdzie :)
  • #9 10964046
    grala1
    Ocena: 5052
    Immo1 więc do odczytu motorola 68hc05.
Użytkownik ma problem z odczytem kodu PIN do immobilizera w VW Sharan z 1999 roku przy użyciu programu VAG TACHO USB 3.01. Podczas próby odczytu pojawia się komunikat o "nieznanych danych EEPROM", co sugeruje problemy z odczytem pamięci. Użytkownicy sugerują ponowny odczyt wsadu oraz sprawdzenie, czy wybrano odpowiedni typ puszki immo. Wskazano, że immobilizer to Immo1, co oznacza, że do odczytu potrzebny jest procesor Motorola 68HC05. Użytkownik potwierdził, że transponder w kluczu ma formę czarnego prostokącika.
