BSOD BAD_POOL_HEADER 0x00000019 - dxgmms1.sys na Windows 7 SP1, jak naprawić?
halidziak 27 Sty 2014 18:29 2100 19
  • #1 13227608
    halidziak
    czy ktoś mógłby zidentyfikować źródło błędu oto log zrobiony programem BlueScreenView
    oto kilka najczęstszych:
    Dump File : 012714-13603-01.dmp
    Crash Time : 2014-01-27 14:34:11
    Bug Check String : BAD_POOL_HEADER
    Bug Check Code : 0x00000019
    Parameter 1 : 0x00000020
    Parameter 2 : 0xabfaa548
    Parameter 3 : 0xabfaa580
    Parameter 4 : 0x0a070805
    Caused By Driver : dxgmms1.sys
    Caused By Address : dxgmms1.sys+503c
    File Description : DirectX Graphics MMS
    Product Name : Microsoft® Windows® Operating System
    Company : Microsoft Corporation
    File Version : 6.1.7601.17514 (win7sp1_rtm.101119-1850)
    Processor : 32-bit
    Crash Address : ntkrnlpa.exe+120c6b
    Stack Address 1 : ntkrnlpa.exe+121a76
    Stack Address 2 : dxgmms1.sys+503c
    Stack Address 3 : dxgmms1.sys+22e8d
    Computer Name :
    Full Path : C:\Windows\Minidump\012714-13603-01.dmp
    Processors Count : 2
    Major Version : 15
    Minor Version : 7601
    Dump File Size : 160 776
    Dump File Time : 2014-01-27 14:34:55
    Dump File : 012714-15256-01.dmp
    Crash Time : 2014-01-27 13:41:11
    Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
    Bug Check Code : 0x1000007e
    Parameter 1 : 0xc0000005
    Parameter 2 : 0x8f08b37d
    Parameter 3 : 0x8d70bbd4
    Parameter 4 : 0x8d70b7b0
    Caused By Driver : Unknown_Module_00000000
    Caused By Address : Unknown_Module_00000000+2
    File Description :
    Product Name :
    Company :
    File Version :
    Processor : 32-bit
    Crash Address :
    Stack Address 1 :
    Stack Address 2 :
    Stack Address 3 :
    Computer Name :
    Full Path : C:\Windows\Minidump\012714-15256-01.dmp
    Major Version : 15
    Dump File Size : 131 072
    Dump File Time : 2014-01-27 13:42:19
    Dump File : 012614-15334-01.dmp
    Crash Time : 2014-01-26 23:09:26
    Bug Check String : IRQL_NOT_LESS_OR_EQUAL
    Bug Check Code : 0x0000000a
    Parameter 1 : 0xff1e302c
    Parameter 2 : 0x00000002
    Parameter 3 : 0x00000001
    Parameter 4 : 0x8287cc05
    Caused By Driver : ntkrnlpa.exe
    Caused By Address : ntkrnlpa.exe+40c9b
    File Description : NT Kernel & System
    File Version : 6.1.7601.18113 (win7sp1_gdr.130318-1533)
    Processor : 32-bit
    Crash Address : ntkrnlpa.exe+40c9b
    Stack Address 1 : ntkrnlpa.exe+76c05
    Stack Address 2 :
    Stack Address 3 :
    Computer Name :
    Full Path : C:\Windows\Minidump\012614-15334-01.dmp
    Major Version : 15
    Dump File Size : 160 840
    Dump File Time : 2014-01-26 23:10:10
    Dump File : 012614-13696-02.dmp
    Crash Time : 2014-01-26 14:43:08
    Bug Check String : KERNEL_MODE_EXCEPTION_NOT_HANDLED
    Bug Check Code : 0x1000008e
    Parameter 2 : 0x828452bc
    Parameter 3 : 0x96cb7bc0
    Parameter 4 : 0x00000000
    Caused By Address : ntkrnlpa.exe+392bc
    Processor : 32-bit
    Crash Address : ntkrnlpa.exe+392bc
    Stack Address 1 : ntkrnlpa.exe+266278
    Stack Address 2 : ntkrnlpa.exe+269d4f
    Stack Address 3 : ntkrnlpa.exe+226449
    Computer Name :
    Full Path : C:\Windows\Minidump\012614-13696-02.dmp
    Major Version : 15
    Dump File Size : 160 824
    Dump File Time : 2014-01-26 14:43:52
    oto jeszcze cieplutki BSOD z przed chwili
    Dump File : 010814-14149-01.dmp
    Crash Time : 2014-01-08 17:36:43
    Bug Check String : NTFS_FILE_SYSTEM
    Bug Check Code : 0x00000024
    Parameter 1 : 0x001904fb
    Parameter 2 : 0xa0607a8c
    Parameter 3 : 0xa0607670
    Parameter 4 : 0x82883ef8
    Caused By Driver : Ntfs.sys
    Caused By Address : Ntfs.sys+1aac3
    File Description : Sterownik systemu plików NT
    Product Name : System operacyjny Microsoft® Windows®
    File Version : 6.1.7600.16385 (win7_rtm.090713-1255)
    Processor : 32-bit
    Crash Address : ntkrnlpa.exe+dec2c
    Stack Address 1 : Ntfs.sys+1aac3
    Stack Address 2 : Ntfs.sys+191cd
    Stack Address 3 : ntkrnlpa.exe+7ec1a
    Computer Name :
    Full Path : C:\Windows\Minidump\010814-14149-01.dmp
    Major Version : 15
    Dump File Size : 160 784
    Dump File Time : 2014-01-08 17:37:26
  • #2 13227626
    beo
    Poziom 37  
    Ocena: 238
    A jakieś dane na temat sprzętu? Wstaw screen z Crystal Disk Info.
  • #3 13227701
    LA72
    Poziom 41  
    Ocena: 1666
    Wykonaj test pamięci RAM za pomocą memtest.
    Podaj dane SMART dysku.
    Pełne dane o komputerze w tym dziale są wymogiem, z uwzględnieniem zasilacza (marka, model).
  • #4 13228397
    halidziak
    Mój Sprzęt:
    Windows 7 home premium 32-Bit
    grafika nvidia geforce gts 250
    4G ram
    procek AMD phenom II 2x550
    płyta główna ASUS M4A77TD pro
    zasilacz: Modecom Premium 500W Pro
    CrystalDiskInfo 4.5.0 (C) 2008-2012 hiyohiyo
    Crystal Dew World : http://crystalmark.info/
    OS : Windows 7 Home Premium Edition SP1 [6.1 Build 7601] (x86)
    Date : 2014/01/27 20:47:47
    -- Controller Map ----------------------------------------------------------
    - ATA Channel 0 (0) [ATA]
    + ATA Channel 1 (1) [ATA]
    - WDC WD5000AADS-00S9B0 ATA Device
    + ATA Channel 0 (0) [ATA]
    - Optiarc DVD RW AD-5240S ATA Device
    - ATA Channel 1 (1) [ATA]
    + Standardowy podwójny kontroler PCI IDE [ATA]
    - ATA Channel 0 (0)
    - ATA Channel 1 (1)
    - ATA Channel 0 (0)
    - ATA Channel 1 (1)
    -- Disk List ---------------------------------------------------------------
    (1) WDC WD5000AADS-00S9B0 : 500.1 GB [0-3-1, pd1]
    Model : WDC WD5000AADS-00S9B0
    Firmware : 01.00A01
    Serial Number : WD-WCAV99283344
    Disk Size : 500.1 GB (8.4/137.4/500.1)
    Buffer Size : 32767 KB
    Queue Depth : 32
    # of Sectors : 976773168
    Rotation Rate : Unknown
    Interface : Serial ATA
    Major Version : ATA8-ACS
    Minor Version : ----
    Transfer Mode : SATA/300
    Power On Hours : 8279 godzin
    Power On Count : 3376 count
    Temparature : 30 C (86 F)
    Health Status : dobry
    Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
    APM Level : ----
    AAM Level : 80FEh [OFF]
    -- S.M.A.R.T. --------------------------------------------------------------
    ID Cur Wor Thr RawValues(6) Attribute Name
    01 200 200 _51 000000000002 Częstotliwość pojawiania się błędów podczas odczytu RAW
    03 194 186 _21 000000000CE4 Czas potrzebny do "rozkręcenia" talerzy dysku
    04 _97 _97 __0 000000000DAD Ilość cykli start/stop
    05 200 200 140 000000000000 Ilość realokowanych sektorów
    07 200 200 __0 000000000000 Częstotliwość błędów podczas pozycjonowania
    09 _89 _89 __0 000000002057 Liczba godzin pracy dysku
    0A 100 100 __0 000000000000 Liczba prób uruchomienia osi napędowej dysku
    0B 100 100 __0 000000000000 Liczba prób kalibracji
    0C _97 _97 __0 000000000D30 Llość skończonych operacji start/stop
    C0 200 200 __0 0000000001DD Ilość naprawionych cykli wyłączenia
    C1 149 149 __0 000000025AA3 Ilość cykli do tak zwanej "Landing Zone"
    C2 113 _97 __0 00000000001E Temperatury dysku (ogólna)
    C4 200 200 __0 000000000000 Liczba remapowanych operacji
    C5 200 200 __0 000000000000 Liczba sektorów niestabilnych (oczekujących na remapowanie)
    C6 200 200 __0 000000000000 Ilość nie naprawionych błędów
    C7 200 200 __0 000000000070 Liczba błędów CRC podczas pracy w trybie Ultra DMA
    C8 200 200 __0 000000000000 Liczba błędów zapisu
    -- IDENTIFY_DEVICE ---------------------------------------------------------
    0 1 2 3 4 5 6 7 8 9
    000: 427A 3FFF C837 0010 0000 003F 003F 0000 0000 0000 Bz?..7.......?......
    010: 2020 2020 2057 442D 5743 3939 3939 3238 3333 3434 WD-WCAV99283344
    020: 0000 FFFF 0032 3031 2E30 3031 3031 5744 4320 5744 .....201.00A01WDC WD
    030: 3530 3030 4141 4453 2D30 3942 3942 3020 2020 2020 5000AADS-00S9B0
    040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00 ..../.
    050: 4001 0000 0000 0007 3FFF 003F 003F FC10 00FB 0110 @.......?....?......
    060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000 ...........x.x.x.x..
    070: 0000 0000 0000 0000 0000 1706 1706 0000 0044 0040 .................D.@
    080: 01FE 0000 746B 7F61 4123 BC41 BC41 4123 407F 0037 ....tk.aA#ti.AA#@..7
    090: 0037 0000 FFFE 0000 80FE 0000 0000 0000 0000 0000 .7..................
    100: 6030 3A38 0000 0000 0000 0000 0000 0000 5001 4EE1 `0:8............P.N.
    110: 5869 6BF8 0000 0000 0000 0000 0000 0000 0000 401C Xik...............@.
    120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000 @................)..
    130: 0000 0000 0000 16D9 0000 0000 0000 0000 0000 0000 ....................
    140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000 ....................
    150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
    160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
    170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
    180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
    190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
    200: 0000 0000 0000 0000 0000 3037 3037 0000 0000 0000 ............07......
    210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
    220: 0000 0000 101E 0000 0000 0000 0000 0000 0000 0000 ....................
    230: 0000 0000 0000 0000 0001 0000 0000 0000 0000 0000 ....................
    240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
    250: 0000 0000 0000 0000 0000 23A5 ..........#.
  • #5 13228433
    LA72
    Poziom 41  
    Ocena: 1666
    Jak wyglądał test pamięci RAM?
    Jeśli wynik był pozytywny to uruchom komputer w trybie awaryjnym.
    Sprawdź czy działa prawidłowo.
    Jeśli tak, to odinstaluj sterowniki do karty graficznej (w tym trybie).
    Uruchom ponownie komputer.
    Po restarcie sam powinien znaleźć i doinstalować oprogramowanie do GFX.
    Po tym zabiegu czeka cię ponowny restart systemu.
    Gdy system się poprawnie załaduje, wykonaj testy za pomocą OCCT dla GPU. Minimum 5 minut (na początek).
    Jak komputer jeszcze będzie działał wstaw wykresy w pliku spakowanym na forum.
    Podczas testu GPU obserwuj temperatury.
    Wykonaj pomiar napięć "zasilacza" za pomocą miernika.
  • #6 13228699
    halidziak
    memtest wykazał 149504 błędy w teście 9 czyli random number sequence co dalej wymienić ram ? w trybie awaryjnym zrobiłem jak pisałeś. Po deinstalacji sterownika pierwszy raz komputer się uruchomił normalnie po restarcie odrazu zrobił się czarny ekran i reset z automatu kilka razy już.
  • #7 13228712
    LA72
    Poziom 41  
    Ocena: 1666
    Czy pamięć 4GB jest w jednej kości czy w kilku?
    Jeśli więcej niż jeden blok to przetestuj powtórnie każdy z osobna, czyli jeden włożony w sloty pamięci i wykonujesz test.
  • #8 13228731
    halidziak
    w 2 oddzielnych
  • #9 13228739
    LA72
    Poziom 41  
    Ocena: 1666
    Jeśli jedna z nich będzie wskazywała błędy to masz winowajcę.
  • #10 13228765
    halidziak
    ok co do tych sterowników instaluje najnowsze to nawet czarny ekran się nie wyśfietl tylko windowsa freezuje a jak usunę to i uruchamiam kompa normalnie to chwila i robi się czarny ekran i resetuje
  • #11 13228779
    LA72
    Poziom 41  
    Ocena: 1666
    Po kolei.
    Zacznij od RAM.
  • #12 13229009
    halidziak
    normalnie cud zrobiłem test 2 kości oddzielnie na slot 0 i nic nie wykryło potem 2 razem na slot 0 i 1 znowu błędy. potem zamieniłem je slotami i znowu błędy potem wsadziłem 1RAM do slot 0 a 2RAM do slotu 2 i nic. czyli 1 slot uszkodzony czy co ? ja tego nie kumam .
    LA72
    Poziom 41  
    Ocena: 1666
    I dlatego w dziale hardware jest wymóg podawania dokładnej konfiguracji komputera.
    Włącznie z podaniem jakie pamięci są zainstalowane, zasilacz, itp.
    W dziale 1.7 instrukcji do płyty jest opisane jak powinno się, jakie pamięci wkładać do slotów.
    W twoim przypadku wyszło, że do nr 1 i 3 lub 0 i 2.
    W celu sprawdzenia poszczególnych złączy pamięci musiałbyś na każdym z nich przetestować jedną pamięć.
    Jeśli na aktualnych ustawieniach RAM w złączach komputer nie wykazuje błędów to proponuję je zostawić w takiej konfiguracji.
    Po każdorazowej zmianie konfiguracji podzespołów bazowych komputera powinno się także wykonać reset BIOS (CMOS).
    Jeśli teraz nie masz już problemów z RAM możesz przejść do powtórnej instalacji sterowników do karty graficznej.
  • #14 13229117
    halidziak
    ok aha i ten reset bios'u zrobiłem zanim napisałeś :D 2 rok elektroniki bijacz
    wiesz ty co coś mi tu nie gra. usuwam sterowniki w trybie awaryjnym -> restart ->instaluje sterowniki windows -> restart -> instaluje nie ważne jaką wersje -> freez systemu i reset (to wszystko się stało bo naszła mnie chęć zaktualizowania wszystkiego od systemu po sterownik grafiki) miałem wersje 306 zaktualizowałem do wersji 332 i w/w zdarzenia.
    dobra po wielu próbach odpuściłem sobie instalowanie sterownika od producenta i po prostu uruchomiłem komputer i narazie działa.
    to BSOD po instalacj sterowników od producenta aż 3x wszystkie takie same
    Dump File : 012714-46051-01.dmp
    Crash Time : 2014-01-27 21:03:08
    Bug Check String :
    Bug Check Code : 0x00000124
    Parameter 1 : 0x00000000
    Parameter 2 : 0x8613d79c
    Parameter 3 : 0x00000000
    Caused By Driver : ntoskrnl.exe
    Caused By Address : ntoskrnl.exe+3249db
    File Version : 6.1.7601.18247 (win7sp1_gdr.130828-1532)
    Processor : 32-bit
    Crash Address : ntoskrnl.exe+3249db
    Stack Address 1 : ntoskrnl.exe+d186d
    Stack Address 2 : ntoskrnl.exe+d2689
    Stack Address 3 : ntoskrnl.exe+7d14b
    Computer Name :
    Full Path : C:\Windows\Minidump\012714-46051-01.dmp
    Major Version : 15
    Dump File Time : 2014-01-27 21:03:39
  • #15 13229981
    LA72
    Poziom 41  
    Ocena: 1666
    Wstaw powtórnie nowe dane SMART do porównania.
  • #16 13230007
    halidziak
    Date : 2014/01/28 10:06:44
    - ATA Channel 0 (0)
    - ATA Channel 1 (1)
    + ATA Channel 0 (0)
    + ATA Channel 1 (1)
    Firmware : 01.00A01
    Queue Depth : 32
    Power On Hours : 8282 godzin
    Power On Count : 3381 count
    Temparature : 31 C (87 F)
    APM Level : ----
    03 188 186 _21 000000000DE6 Czas potrzebny do "rozkręcenia" talerzy dysku
    04 _97 _97 __0 000000000DB2 Ilość cykli start/stop
    07 100 253 __0 000000000000 Częstotliwość błędów podczas pozycjonowania
    09 _89 _89 __0 00000000205A Liczba godzin pracy dysku
    0C _97 _97 __0 000000000D35 Llość skończonych operacji start/stop
    C0 200 200 __0 0000000001E0 Ilość naprawionych cykli wyłączenia
    C1 149 149 __0 000000025ABF Ilość cykli do tak zwanej "Landing Zone"
    C2 112 _97 __0 00000000001F Temperatury dysku (ogólna)
    0 1 2 3 4 5 6 7 8 9
    -- SMART_READ_DATA ---------------------------------------------------------
    +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
    000: 10 00 01 2F 00 C8 C8 02 00 00 00 00 00 00 03 27 .../...........'
    010: 00 BC BA E6 0D 00 00 00 00 00 04 32 00 61 61 B2 ...........2.aa.
    020: 0D 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00 .......3........
    030: 00 00 07 2E 00 64 FD 00 00 00 00 00 00 00 09 32 .....d.........2
    040: 00 59 59 5A 20 00 00 00 00 00 0A 32 00 64 64 00 .YYZ ......2.dd.
    050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00 .......2.dd.....
    060: 00 00 0C 32 00 61 61 35 0D 00 00 00 00 00 C0 32 ...2.aa5.......2
    070: 00 C8 C8 E0 01 00 00 00 00 00 C1 32 00 95 95 BF ...........2....
    080: 5A 02 00 00 00 00 C2 22 00 70 61 1F 00 00 00 00 Z......".pa.....
    090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32 ...2...........2
    0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 C8 C8 00 ...........0....
    0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 70 00 00 00 00 .......2...p....
    0C0: 00 00 C8 08 00 C8 C8 00 00 00 00 00 00 00 00 00 ................
    0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    160: 00 00 00 00 00 00 00 00 00 00 82 00 30 2A 01 7B ............0*.{
    170: 03 00 01 00 02 7F 05 00 00 00 00 00 00 00 00 00 ................
    180: 00 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00 ................
    190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 94 ................
    -- SMART_READ_THRESHOLD ----------------------------------------------------
    000: 10 00 01 33 C8 C8 00 00 00 00 00 00 00 00 03 15 ...3............
    010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 ................
    020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00 ................
    030: 00 00 07 00 64 64 00 00 00 00 00 00 00 00 09 00 ....dd..........
    040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 ................
    050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00 ................
    060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00 ................
    070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00 ................
    080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00 ................
    090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00 ................
    0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00 ................
    0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00 ................
    0C0: 00 00 C8 00 C8 C8 00 00 00 00 00 00 00 00 00 00 ................
    160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D5 ................
    https://drive.google.com/file/d/0B0ehTVn-_mWkMEFxQnF2YUNHWEE/edit?usp=sharing
    to screen z Cristal disk info
  • #17 13230053
    LA72
    Poziom 41  
    Ocena: 1666
    Kod: Text
    Zaloguj się, aby zobaczyć kod
    Dysk nie zmieniła ważnych parametrów, więc błąd dotyczy wyłącznie sterownika w systemie.
  • #18 13230101
    halidziak
    hmm... obstawiam sterownik graficzny. chociaż czytałem troche o tych BSOD i to może wywoływać każdy sterownik który wchodzi w konflikt z innym tak ?
  • #19 13231633
    halidziak
    odkryłem problem to sterownik od asus network adapter.
    odpalam kompa z włączonym tym sterownikiem -> odpalam grę -> BSOD.
    włączam tą samą grę, wyłączam ten sterownik, normalnie śmiga przez 4h, włączam ten sterownik gdy ta gra jest włączona, BSOD.
  • #20 13233803
    halidziak
    zamykam temat dziękuje za pomoc teraz już nie ma BSOD tylko komputer czasami sam się resetuje a czemu to już na inny temat.
Użytkownik zgłosił problem z błędem BSOD BAD_POOL_HEADER (0x00000019) spowodowanym przez sterownik dxgmms1.sys na systemie Windows 7 SP1. W odpowiedzi na zapytanie, uczestnicy dyskusji zasugerowali przeprowadzenie testów pamięci RAM za pomocą memtest oraz sprawdzenie stanu dysku twardego przy użyciu CrystalDiskInfo. Po wykonaniu testów, użytkownik odkrył, że pamięć RAM wykazuje błędy, co sugeruje jej uszkodzenie. Po odinstalowaniu sterowników karty graficznej i ich ponownej instalacji, problem z BSOD został częściowo rozwiązany, jednak komputer nadal czasami się resetował. Ostatecznie zidentyfikowano, że problemem był sterownik adaptera sieciowego ASUS, który powodował BSOD podczas uruchamiania gier. Po wyłączeniu tego sterownika, komputer działał stabilnie.
