Mam następujące błędy w aucie, może ktoś z kolegów orientuje się jak je usunąć, tzn naprawić usterki? /chodzi mi tylko o te najważniejsze, mające duże znaczenie. Z góry dziękuje za pomoc.
Kody błędu poniżej:
VCDS-Lite Version: Release 1.2
Wednesday, 30 December 2015, 13:29:40:0
Chassis Type: 1U - Skoda Octavia I
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,56,76
Address 01: Engine Labels: 038-906-012-AGR.LBL
Controller: 038 906 012 CL
Component: 1,9l R4 EDC 0110SG 3316
Coding: 00002
Shop #: WSC 21084
VCID: 5CCB1773DF33
TMBBP21U712437257 SKZ7Z0Y0580496
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-00 - -
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.LBL
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480
VCID: 2B2984AFCA1D
No fault code found.
Address 08: Auto HVAC Labels: 1Ux-907-044.LBL
Controller: 1U1 907 044 A
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 31480
VCID: 301393C3E33B
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 6Q0 909 605
Component: 08 AIRBAG VW5 0004
Coding: 12344
Shop #: WSC 31480
VCID: F49BDFD3D7A3
Address 17: Instruments Labels: 1U0-920-xxx-17.LBL
Controller: 1U0 920 810 F
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 03112
Shop #: WSC 00186
VCID: 301393C3E33B
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
01176 - Key
07-10 - Signal too Low - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
VCID: F093D3C3A3BB
Address 46: Central Conv. Labels: 1J0-959-799.LBL
Controller: 1J0 959 799 AH
Component: 5H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31480
VCID: 847B8F138703
6 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01333 - Door Control Module; Rear Left (J388)
49-10 - No Communications - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
54-10 - Incorrectly Equipped - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
27-00 - Implausible Signal
End ----------------------------------------
Kody błędu poniżej:
Coding: 00002
Shop #: WSC 21084
VCID: 5CCB1773DF33
2 Faults Found:
P1654 - 35-00 - -
P1570 - 35-00 - -
Readiness: N/A
Coding: 0021505
Shop #: WSC 31480
VCID: 2B2984AFCA1D
Coding: 01000
Shop #: WSC 31480
VCID: 301393C3E33B
Coding: 12344
Shop #: WSC 31480
VCID: F49BDFD3D7A3
Coding: 03112
Shop #: WSC 00186
VCID: 301393C3E33B
2 Faults Found:
01176 - Key
Coding: 00006
Shop #: WSC 31480
VCID: F093D3C3A3BB
Coding: 04097
Shop #: WSC 31480
VCID: 847B8F138703
6 Faults Found:
35-00 - -
35-00 - -
