Rozumiem, lecz dla pewności jakbyś mógł przejrzeć log, czy to na pewno wina tego, a może coś źle robię.
Cytat: Aug 1 00:00:09 syslogd started: BusyBox v1.17.4
Aug 1 00:00:09 kernel: klogd started: BusyBox v1.17.4 (2015-11-11 22:29:57 CST)
Aug 1 00:00:09 kernel: Linux version 2.6.36.4brcmarm (chengche@ubuntu) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Wed Nov 11 22:39:08 CST 2015
Aug 1 00:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug 1 00:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 00:00:09 kernel: Machine: Northstar Prototype
Aug 1 00:00:09 kernel: Ignoring unrecognised tag 0x00000000
Aug 1 00:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug 1 00:00:09 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 00:00:09 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 00:00:09 kernel: Memory: 125488k/125488k available, 5584k reserved, 0K highmem
Aug 1 00:00:09 kernel: Virtual kernel memory layout:
Aug 1 00:00:09 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 00:00:09 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 00:00:09 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 00:00:09 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 00:00:09 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 00:00:09 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 00:00:09 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 00:00:09 kernel: .text : 0x80038000 - 0x803e3000 (3756 kB)
Aug 1 00:00:09 kernel: .data : 0x803fc000 - 0x8041ef40 ( 140 kB)
Aug 1 00:00:09 kernel: Mount-cache hash table entries: 512
Aug 1 00:00:09 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug 1 00:00:09 kernel: ACP (Accelerator Coherence Port) enabled
Aug 1 00:00:09 kernel: bio: create slab <bio-0> at 0
Aug 1 00:00:09 kernel: PCI: no core
Aug 1 00:00:09 kernel: PCI: Fixing up bus 0
Aug 1 00:00:09 kernel: PCI: Fixing up bus 1
Aug 1 00:00:09 kernel: PCI: scanning bus 0 !!!
Aug 1 00:00:09 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 00:00:09 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 00:00:09 kernel: pflash: found no supported devices
Aug 1 00:00:09 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 00:00:09 kernel: Creating 4 MTD partitions on "bcmsflash":
Aug 1 00:00:09 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 00:00:09 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 00:00:10 kernel: 0x0000001ef060-0x000000ff0000 : "rootfs"
Aug 1 00:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 00:00:10 kernel: === PPTP init ===
Aug 1 00:00:10 kernel: Registering the dns_resolver key type
Aug 1 00:00:10 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 00:00:10 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 00:00:10 kernel: Disabling lock debugging due to kernel taint
Aug 1 00:00:10 kernel: et_module_init: passivemode set to 0x0
Aug 1 00:00:10 kernel: et_module_init: txworkq set to 0x1
Aug 1 00:00:10 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 00:00:10 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug 1 00:00:10 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug 1 00:00:10 kernel: bcm_robo_enable_switch: EEE is disabled
Aug 1 00:00:10 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug 1 00:00:10 kernel: wl_module_init: passivemode set to 0x0
Aug 1 00:00:10 kernel: wl_module_init: txworkq set to 0x1
Aug 1 00:00:10 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug 1 00:00:10 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 00:00:10 kernel: External imprecise Data abort at addr=0x2ae44004, fsr=0x1c06, pc=0x2ab067a0 lr=0x2ad0c204 ignored.
Aug 1 00:00:10 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 00:00:10 stop_nat_rules: apply the redirect_rules!
Aug 1 00:00:10 WAN Connection: Ethernet link down.
Aug 1 00:00:18 dnsmasq[374]: warning: interface ppp1* does not currently exist
Aug 1 00:00:18 RT-AC1200G+: start httpd
Aug 1 00:00:19 syslog: Generating SSL certificate...
Aug 1 00:00:19 disk monitor: be idle
Aug 1 00:00:19 hour monitor: daemon is starting
Aug 1 00:00:19 hour monitor: daemon terminates
Aug 1 00:00:19 miniupnpd[408]: version 1.9 started
Aug 1 00:00:19 miniupnpd[408]: HTTP listening on port 52621
Aug 1 00:00:19 miniupnpd[408]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 00:00:20 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 00:00:20 syslog: module leds-usb not found in modules.dep
Aug 1 00:00:21 kernel: SCSI subsystem initialized
Aug 1 00:00:24 kernel: scsi 0:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Aug 1 00:00:24 kernel: scsi 0:0:0:0: Attached scsi generic sg0 type 5
Aug 1 00:00:24 kernel: scsi 1:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Aug 1 00:00:24 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Aug 1 00:00:24 kernel: sd 1:0:0:0: [sda] Attached SCSI removable disk
Aug 1 00:00:49 hour monitor: daemon is starting
Aug 1 00:00:49 hour monitor: ntp is not syn
Aug 1 00:00:56 rc_service: wanduck 363:notify_rc restart_wan_if 0
Aug 1 00:00:56 kernel: Attempt to kill tasklet from interrupt
Aug 1 00:00:58 rc_service: wanduck 363:notify_rc restart_wan_if 1
Aug 1 00:01:07 WAN Connection: Fail to connect with some issues.
