Jak naprawić błąd flashowania Nokia 3510i z MT-BOX?
revolt 10 Lut 2007 13:17 2517 22
  • #1 3552085
    revolt
    Ocena: 186
    Processing File: rh9__04.010
    Boot...
    ASIC ID: 1120
    DCT4
    u_2nd.fia
    u_amd.fia
    84C2AC412D4E5D9033D2E128094D
    Configuration Info (9F):
    Number of Flashes: 2
    01000000: Samsung, 00EC 22FA 0000 0011, 10
    02000000: NotUsed, 0000 0001 0000 0000, 0
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Erase[7.94 MB]...
    erasing region [01000000 to 0100FFFF]
    erasing region [01010000 to 017EFFFF]
    in 57.42s
    Flash[5.26 MB]...in 25.94s
    * * Processed file in 91.64 seconds
    Processing File: cp_pB_04.010
    Boot...
    ASIC ID: 1120
    DCT4
    u_2nd.fia
    u_amd.fia
    84FED50F81D790C552C9C75F9912
    Erase[1.06 MB]...
    erasing region [01580000 to 0168FFFF]
    in 8.70s
    Flash[0.17 MB]...in 0.86s
    * * Processed file in 17.83 seconds
    Extract content...fail
    Processing File: rh9__04.01B
    Boot...
    ASIC ID: 1120
    DCT4
    u_2nd.fia
    u_amd.fia
    Erase[1.06 MB]...
    in 8.59s
    Flash[0.91 MB]...in 4.50s
    * * Processed file in 21.38 seconds
    * * * Phone flashing done in 3:14 minutes
    Post Flash serial tunning of phone....
    Pooling mode for full factory set...
    Phone not responding, try to set manually!
    Flashowałem 6030 potem i wszystko OK. Kabel przejścia ma. Tel był OK i przedwczoraj był flashowany tym samym boxem. Sprawdzałem na 1,29 i 1,26 na 2 różnych kompach. Od wczoraj tak juz trzecią załatwiłem. Jak to naprawić? Wygląda jakby w local mode nie wchodziło
    Tornado postawiło telefon ale po ponownym flashu padł spowrotem. Robione na innym kablu.
    Phone is in: Phone is not responding, power on phone!
    Processing File: rh19__05.300
    Boot...
    ASIC ID: 1120
    DCT4
    u_2nd.fia
    u_amd.fia
    84109DCAFECAFDABCE41B2027160
    01000000: Amd, 0001 277E 0002 7111, 10
    Erase[8.00 MB]...
    request erase [01000000 to 0100FFFF]
    request erase [01010000 to 0154FFFF]
    request erase [01680000 to 017EFFFF]
    request erase [01EB0000 to 01FEFFFF]
    Waiting response for 300 Sec...in 33.20s
    Flash[5.24 MB]...in 16.45s
    * * Processed file in 57.95 seconds
    Processing File: rh19__05.30.ucp_ore
    Low level format...fail
    Boot...
    ASIC ID: 1120
    DCT4
    u_2nd.fia
    u_amd.fia
    Erase[1.19 MB]...
    request erase [01550000 to 0167FFFF]
    Waiting response for 300 Sec...in 6.77s
    Flash[0.50 MB]...in 1.66s
    * * Processed file in 48.38 seconds
    Processing File: rh19__05.30b
    Boot...
    ASIC ID: 1120
    DCT4
    u_2nd.fia
    u_amd.fia
    Erase[1.19 MB]...
    Waiting response for 300 Sec...in 6.83s
    Flash[0.93 MB]...in 3.24s
    * * Processed file in 18.38 seconds
    * * * Phone flashing done in 3: 9 minutes
    to z 3100.
    koledzy dam 100 pkt za rozwiazanie
  • #3 3553473
    revolt
    Ocena: 186
    kabel na pewno dobry. sprawdzałem na tym którym flashowałem pod tornado i poszło.
    systemcom
    Ocena: 40
    Ja jedna proponuje inny kabel miałem dokładnie podobny przypadek!!! Kabel to groszowe sprawy warto spróbowac!
  • #5 3554701
    revolt
    Ocena: 186
    Koledzy piszę, że sprawdzony kabel na 100% nawet na drugim sprawdzałem i to samo. Obydwa OK
    systemcom
    Ocena: 40
    To moze sprawdz styki w box czy zaden nie jest zagiety lub zabrudzony!?
    fischer8
    Spoczywaj w Pokoju
    Ocena: 116
    KamBys napisał:
    akurat mt-boxa nie uzywam, ale podejrzewam ze fon sie w local mode sam nie zalacza i bedziesz musial w danym momencie (extract cnt i resety) wlacznikiem go zalczyc i wtedy wskoczy w local mode
    Akurat telefon jeżeli jest sprawny to wystarczy podpiąć tylko styki od baterii plus minus i bsi i telefon jest w lokal mode.Zmieniając wartość rezystora na bsi 0d 3,3kOm do 7,5 kOm uzyskasz np.test mode.
    Mt-box potrzebuje na bsi resystora o wartości 3,3-7,5 kOm.
    pozdrawiam Bogdan
  • #9 3555465
    revolt
    Ocena: 186
    Kable są na 100% OK. Jedna 3510i była flashowana kablem ze zestawu i wszystko było OK. Teraz zima.
    Telefon po podłączeniu ładnie w local wchodzi ale już po flashowaniu nie chce.
    LOG z innej 6030. Te się ładnie flashują :/ Już nie wiem co to może być
    Processing File: rm74__5.110
    Boot...
    ASIC ID: 2031
    DCT4
    u_2nd.fia
    u_intel.fia
    8418A63649104F7E54D4EF340F07
    01000000: SGS, 0020 882E 0000 7121, 11
    Erase[8.50 MB]...
    erasing region [01000000 to 0101FFFF]
    erasing region [01020000 to 017BFFFF]
    erasing region [01F20000 to 01FDFFFF]
    in 77.36s
    Flash[6.77 MB]...in 46.02s
    * * Processed file in 131.58 seconds
    Processing File: rm74__5.11.image_ora_pl
    Boot...
    ASIC ID: 2031
    DCT4
    u_2nd.fia
    u_intel.fia
    84C9640F9092A54732AD69DCFE0F
    Erase[3.12 MB]...
    erasing region [01C00000 to 01F1FFFF]
    in 26.45s
    Flash[0.88 MB]...in 5.55s
    * * Processed file in 39.70 seconds
    Extract content...OK
    Processing File: rm74__5.11b
    Boot...
    ASIC ID: 2031
    DCT4
    u_2nd.fia
    u_intel.fia
    84879C4E108A8D51918419D5D5BA
    Erase[4.25 MB]...
    erasing region [017C0000 to 01BFFFFF]
    in 35.55s
    Flash[1.20 MB]...in 8.16s
    * * Processed file in 51.56 seconds
    * * * Phone flashing done in 3:52 minutes
    V 5.11/30-05-06/RM-74 (c) Nokia.
    IMEI: 357XXXXXXXXXXXX
    Factory Default Settings...OK
    djjack
    Ocena: 27
    Sprawdz na zasilaczu tzn podłacz zasilacz do mt-box moze masz mała wydajnosc usb (pradowa )w czasie przełaczania lub fleshowania i nie programuje prawidłowo kosci .Jeszcz sprawdz odłacz wszystko co masz na usb i zostaw samego mt-boxa .
    michałbak1
    Ocena: 3
    Witam a kolega ma włączoną opcje DisableVPP ???
  • #12 3559307
    revolt
    Ocena: 186
    Podłączałem ładowarkę i nic. Disable VPP też próbowałem. Chyba odeślę na gwaranję tego boxa. Posprawdzałem przejściówkę też wszystko OK.
    djjack
    Ocena: 27
    Wtakim razie masz do przeinstalowania winde jakies pliki z mt box sie zagubiły w systemie .Najwyrazniej cos zainstalowałes przez te dwa dni i dlatego mt-box sie wysypał.Box masz napewno sprawnego wiec szkoda zachodu na wysyłke
  • #14 3568535
    revolt
    Ocena: 186
    Okazało się, że box jest OK. U kumpla wszystko ładnie chodzi. Jego tornado u mnie zachowuje się jak mt-box- nie robi extract CP itp. Nie wiem co sie mogło stać. Zasilacz mam konkretny nie ma problemu z zasilaniem boxa, zresztą do niedawna robił bez problemu. Reinstalka windy nic nie dała.
    Na laptopie, na HUBIE to samo. Nie wiem jakaś żyła wodna się zrobiła czy co?
    rafal8916
    Specjalista - spawarki
    Ocena: 326
    A jaką masz wersję windy?? może to ona komplikuje ci sprawę. Kumpel może mieć np. XP z sp2 a ty wersję bez serwice packa i to system wszystko komplikuje. Z doświadczenia wiem że sp2 rozwiązywał wiele problemów ze współpracą boxów z pc. Jeżeli masz jakąś inną wersję systemu (inny serwice pack) to zainstaluj tą co ma kumpel i wtedy spróbuj.
    Jak coś to pisz dalej. Będziemy coś myśleć
    Pozdro
  • #16 3568584
    revolt
    Ocena: 186
    Mam XP z SP2. Kumpel też. Na tym systemie box działał i np. stacjonarnego nie ruszałem i po dwóch tygodniach wracam (na wyjeździe korzystałem z laptopa) i zonk. Nie działa.
    Jutro pójdę na świeże powietrze spróbuję albo do piwnicy. Może boxik potrzebuje spacerku.
  • #17 3568587
    rafal8916
    Ocena: 326
    A może jakiś konflikt sprzętowy masz, co raczej mało przwdopodobne ale nie zaszkodzi sprawdzić
  • #18 3569999
    revolt
    Ocena: 186
    Specjalnie trzeciego kompa wytargałem z windą 2000. I to samo :(
    200pkt temu kto mi powie czemu na XP 40m dalej box działa a u mnie nie.
    Brzymeq
    Poziom 32  
    Ocena: 118
    masz mt boxa ? bo nie zrozumialem, jesli tak to odinstaluj wszystko z griffin team, zainstaluj instalke z supportu z wersja merryxmass w naziwe, a potem wgraj patcha z wersja 1.29.1.1 tylko koniecznie musi byc instalka ta co podalem, na inne j sa problemy albo sie nie odpala wogole. no i po odinstalowaniu usun wszystki pliki zwiazane z griffinem z folderu common files w /program files
    jeslie nie to :
    z VPP mozna probowac albo pomin erase, ew sproboj wylaczyc auto przywracanie ustawien i bez tego zrobic a potem sobie z klawisza zrobisz. ew. papatrz czy czegos nie wlczyles w extra options ;]
  • #20 3573165
    revolt
    Ocena: 186
    instalki te co podałeś. Instalowane na czysty win po reinstalce.
    michałbak1
    Ocena: 3
    No mi po przeczytaniu całego posta jeszcze raz wpadła do głowy myśl nic nie piszesz o kablu usb jakiego uzywasz. Miałem kiedyś na samym początku użytkowania tego boxa może troszke inny problem z fleszowaniem niż twój ale nie zaszkodzi użyć dobrej jakości kabla w standardzie usb2.0. Pozatym wybierz pliki do fleszowania ręcznie i spróbuj jeszcze raz. Pozatym myśle że nie zapomniałeś o update boxa przez progam update tool 3.5.
  • #23 3576582
    revolt
    Ocena: 186
    Na 4 kablach sprawdzane ale już problem został rozwiązany. Okazało sie, że na kompie na którym ściągałem softy coś się popierniczyło z NTFSem chyba. Cos jakby pliki miały tylko do odczytu czy nie wiem jak to nazwać. Ściągnałem na nowo softa na kompie z fat32 i poszło. Pliki z tego kompa zadziałały też na innych. Kluczem do problemu była chyba jakaś automatyczna aktualizacja windowsa. Nie wiem jak to inaczej wyjaśnić. Stare ściągane pliki były OK (dlatego np 6030 się flashowało).
    Każdemu wysyłam po równo punktów
Problem dotyczył błędu podczas flashowania telefonu Nokia 3510i za pomocą programatora MT-BOX. Pomimo poprawnego kabla i prawidłowego wejścia telefonu w tryb lokalny, proces flashowania kończył się niepowodzeniem, zwłaszcza na laptopie. Sprawdzono różne kable, styki w boxie, opcje oprogramowania (DisableVPP, pomijanie erase), a także zasilanie i wersję systemu operacyjnego (Windows XP SP2). Próby reinstalacji systemu i użycia innego komputera nie przyniosły efektu. Ostatecznie problemem okazał się system plików na komputerze, z którego pobierano oprogramowanie – pliki na partycji NTFS miały ograniczenia dostępu, co uniemożliwiało poprawne flashowanie. Po pobraniu softu na komputer z systemem plików FAT32 flashowanie przebiegło pomyślnie. Wskazano również na konieczność aktualizacji oprogramowania boxa oraz użycie kabli USB wysokiej jakości w standardzie USB 2.0.
