Układ wylutowany z inteligentnej wtyczki z pomiarem mocy.
Podłączony pod zasilacz z płytki stykowej i próba zaprogramowania BK7231Flasher.exe.
Logi z programu
Po odczycie ma nastąpić programowanie mimo wielu prób z pinem CEN lub załączaniem zasilania
Logi z programu
Cytat:itp. itp.Backup name is set to kwadata7.
Starting read backup and flash new!
Now is: wtorek, 13 lutego 2024 23:54:13.
Flasher mode: BK7231T
Going to open port: COM5.
Serial port open!
Getting bus... (now, please do reboot by CEN or by power off/on)
Getting bus success!
Going to set baud rate setting (921600)!
Going to start reading at offset 0x00...
Reading 0x00... Ok! Reading 0x1000... Ok! Reading
Cytat:Ok! Reading 0x1FF000... Ok!
Basic read operation finished, but now it's time to verify...
Starting CRC check for 512 sectors, starting at offset 00
CRC matches 0xCCB8AA9B!
All read!
Loaded total 0x200000 bytes
Wrote 2097152 to readResult_BK7231T_QIO_kwadrat7_2024-13-2-23-54-49.bin
Backup 2MB created, now will attempt to extract OBK config.
It's not an OBK config, header is bad
OBK config not found.
Backup 2MB created, now will attempt to extract Tuya config.
Tuya config extractor - magic is at 2023424
Saving debug Tuya decryption data to lastRawDecryptedStrings.bin
Malformed key?
Malformed key?
Malformed key?
Malformed key?
Tuya keys extraction has found 72 keys
Tuya config extracted and shown.
MAC seems to be 18:DE:50:CD:42:0A
Reading file firmwares/OpenBK7231T_QIO_1.17.308.bin...
Loaded 1048576 bytes from firmwares/OpenBK7231T_QIO_1.17.308.bin...
Using BK7231T hack to write QIO - just skip bootloader
Preparing to write data file to chip - resetting bus and baud...
Getting bus failed, will try again - 0/100!
Cytat:Failed to get bus!
