Nazwa: AFYEEV 32A 7.2KW Type2 Type1EV
URL: https://www.aliexpress.com/item/1005007587878624.html
Moduł: BK7231N - CBU-IPEX
Zdjęcia:
Połączenie: https://developer.tuya.com/en/docs/iot/cbuipex-module-datasheet?id=Kaedsyurckrhu
Tuya DP
Zdjęcia:
Tuya DP
"result": {
"category": "qccdz",
"functions": [
"code": "charge_cur_set",
"dp_id": 4,
"type": "Integer",
"values": "{\"unit\":\"A\",\"min\":1,\"max\":255,\"scale\":0,\"step\":1}"
"code": "work_mode",
"dp_id": 14,
"type": "Enum",
"values": "{\"range\":[\"charge_now\",\"charge_pct\",\"charge_energy\",\"charge_schedule\"]}"
"code": "switch",
"dp_id": 18,
"type": "Boolean",
"values": "{}"
"lang_config": {},
"status": [
"code": "forward_energy_total",
"dp_id": 1,
"type": "Integer",
"values": "{\"unit\":\"kW·h\",\"min\":0,\"max\":99999999,\"scale\":2,\"step\":1}"
"code": "work_state",
"dp_id": 3,
"type": "Enum",
"values": "{\"range\":[\"charger_free\",\"charger_insert\",\"charger_free_fault\",\"charger_wait\",\"charger_charging\",\"charger_pause\",\"charger_end\",\"charger_fault\"]}"
"dp_id": 4,
"type": "Integer",
"code": "sigle_phase_power",
"dp_id": 5,
"type": "Integer",
"values": "{\"unit\":\"kW\",\"min\":0,\"max\":99999999,\"scale\":3,\"step\":1}"
"code": "power_total",
"dp_id": 9,
"type": "Integer",
"dp_id": 14,
"type": "Enum",
"code": "switch",
"dp_id": 18,
"type": "Boolean",
"values": "{}"
"code": "temp_current",
"dp_id": 24,
"type": "Integer",
"values": "{\"unit\":\"℃\",\"min\":-40,\"max\":200,\"scale\":0,\"step\":1}"
"code": "charge_energy_once",
"dp_id": 25,
"type": "Integer",
"values": "{\"unit\":\"kW·h\",\"min\":0,\"max\":999999,\"scale\":2,\"step\":1}"
"success": true,
"t": "XXX",
"tid": "XXX"
