Telkom RWT Malwa - Bardzo cichy dźwięk w słuchawce, możliwe złe podłączenie
yurotel 30 Lis 2017 21:12 2613 14
  • Greetings from Serbia,
    I am writing in English because I don't speak Polish. (I speak also Russian and French)
    I have a trouble with a Telkom RWT Malwa. When I connect it, the earpiece is almost mute, I can hear the signal very weakly, as something is misconnected on the print board.
    I connected the wires as I saw on this picture:
    (downloaded from another topic on elektroda.pl)
    So, where can be the defect?
    Best regards,
    Ivan
    yurotel
    Poziom 7  
    yurotel napisał 7 postów. Jest z nami od 2017 roku.
  • #2 16860238
    kangyooni
    Ocena: 100
    Hey, I don't have a circuit diagram right now, I might get some pictures in a few days. Just from the symptom, you probably messed up connecting the dial (3 cables). Try exchanging them.
  • #3 16860378
    krzysiozak
    Poziom 40  
    Ocena: 1154
    Na początek proponuję sprawdzenie samej wkładki słuchawkowej. Wyjąć ją z słuchawki i podłączyć do jakiegoś źródła dźwięku. Od po prostu czy gra.
    At first I suggest you check the headset itself. Remove it from the handset and connect it to a sound source. From simply playing.
  • #4 16860648
    yurotel
    Poziom 7  
    @ kangyooni: I have tried all the combinations of dial connecting and no result. I will be very grateful if you upload the circuit diagram.
    @ krzysiozak: I have already tried to change the headset with a Yugoslav one (dynamic, which is compatible to BN-66) and no result.
  • #5 16860697
    zybex
    Pomocny dla użytkowników
    Ocena: 2939
    green at 10, red at 11, yellow at 12
    Scheme Malwa
    Zener diode D1, D2 - 27V
  • #6 16860824
    krzysiozak
    Poziom 40  
    Ocena: 1154
    And the diagram will be useful to him.
    A schemat na pewno mu się przyda.
    @yurotel
    Teraz miernik w rękę i naprzód.
    Now meter in hand and forward.
    @zybex
    Też posługuję się translatorem.
    I also use a translator.
    Te diody powinny mieć Uf od 500mV do 1000mV.
    These diodes should have Uf from 500mV to 1000mV.
  • #7 16860854
    zybex
    Ocena: 2939
    The most suspect is the anti-terror system. You can disconnect it for a trial. It will work without it. The second suspect element may be a transformer, but it is unlikely. The third eventuality is the mechanical damage to the W-66 headphone. It is also worth checking the resistors and capacitor next to the transformer.
  • #8 16863234
    yurotel
    Poziom 7  
    Thank you for the advice.
    I checked both diodes, and both of them are no good. Now, let's desolder - it is not easy like on Yugoslav print boards...
  • #9 16863332
    zybex
    Ocena: 2939
    Without these diodes it must be heard well. You can insert two rectifiers, eg 1N4007.
    It is still possible to check the cable to the handset itself.
  • #10 16863390
    krzysiozak
    Poziom 40  
    Ocena: 1154
    Which zener diodes are they talking about?
    In a serial or parallel system?
  • #11 16863428
    zybex
    Ocena: 2939
    Zener diodes are only from the bell. They do not affect poor audibility.
  • #12 16881682
    yurotel
    Poziom 7  
    The mission ended unsuccessfully. The result is same, those diodes are not the point.
    How can I examine the transformer?
  • #13 16881760
    zybex
    Ocena: 2939
    The transformer has three windings with the given values. You have to measure them or agree with those on the diagram (20, 37 and 120ohm). You also need to check if there is a breakdown between the primary and secondary windings.
  • #14 16883213
    krzysiozak
    Poziom 40  
    Ocena: 1154
    Należy sprawdzić Tarczę numerową, odłączyć ją, sprawdzić czy prawidłowo zwiera [tylko w momencie nakręcania] obwód rozmowny, i czy prawidłowo jest podłączona, i czy nikt nie poza mieniał kolorowych przewodów od niej.
    Należy miernikiem sprawdzić ciągłość wszystkich obwodów, i także miernikiem czy niema zwarcia w obwodach. Takie telefony są trywialne w naprawie, prostszych urządzeń nie znam.
    Check the number dial, disconnect it, check that it connects [talk-only] only, and that it is properly connected, and that no one outside has used colored wires from it.
    Use a meter to check the continuity of all circuits, and also a meter or a short circuit in the circuits. Such phones are trivial in repair, I do not know of simpler devices.
  • #15 17048122
    yurotel
    Poziom 7  
    I apologize because of no answer till now, but I was very busy.
    I found out where was the defect: when desoldering the diodes, I have damaged the printed connection. I made a bypass and the telephone began to work.
    As anti-shock system I installed a "diak" on the earpiece screws.
    Thank you all very much for the advice.
    Next time I'll come with a Tulipan.
Użytkownik zgłosił problem z telefonem Telkom RWT Malwa, w którym dźwięk w słuchawce był bardzo cichy. Po wymianie połączeń kablowych i sprawdzeniu wkładki słuchawkowej, problem nie ustąpił. Uczestnicy dyskusji sugerowali sprawdzenie diod Zenera, transformatora oraz obwodów. Ostatecznie użytkownik odkrył, że uszkodzenie wystąpiło w połączeniu drukowanym podczas desolderingu diod, co naprawił, tworząc obejście. Telefon zaczął działać poprawnie po tej naprawie.
